Synthetic Oil
Oil of Choice
  • Castrol Syntec/Edge
    Votes: 237 8.5%
  • Royal Purple
    Votes: 327 11.8%
  • AMSOil
    Votes: 400 14.4%
  • Valvoline Synpower
    Votes: 160 5.8%
  • Mobil 1
    Votes: 995 35.8%
  • Other
    Votes: 662 23.8%
  • Total voters
    2,781
dexter
Banned
It's not just the moly, it's across the board not redline. And yes metals have a useful life, I doubt moly is different. An example you might want to look at is calcium, at the end of a oci it is just about useless but the level is still read by the machine that reads uoa's. Even if moly was "worn" to be less effective, you would still see that level. Not only are all the levels off, the magnesium level is high compared to zero, redline doesn't even use magnesium, there is only hints of mag in redline uoa's.
The fact is across the board it isn't redline, there is not much more to say on it.
Mag is from gasoline - read here:
https://www.blackstone-labs.com/report-explanation.php
U&A
2016 3500 SRW
6.4 HEMI
I agree
Read the link in my sig line - not a Diesel oil - a very robust additive package - better then Red Line and other premium oils
GAL $20!
https://shop.advanceautoparts.com/p...0w-40-motor-oil-1-gallon-550046264/11601386-P
PRODUCT DETAILS
Part No. 550046264
Warranty Details (30 DAY REPLACEMENT IF DEFECTIVE)
Shell ROTELLA® T6 Multi-Vehicle full synthetic heavy duty engine oil is gentle enough for gasoline engines, without sacrificing protection in diesels. Blended with lower levels of phosphorous, Shell ROTELLA® T6 Multi-Vehicle is able to meet both API CK-4 and SN performance standards. It also has approval from a wide range of well-known engine makers including Heavy Duty OEMs Volvo, Mack, Mercedes Benz, Detroit Diesel; medium duty diesel manufacturers Ford, and Dodge; and gasoline pickup/car manufacturers such as GM, Ford, Chrysler, Toyota, Chevrolet, Dodge. These approvals make Shell ROTELLA® T6 Multi-Vehicle ideal for a variety of vehicles and applications.
Product Features:
  • Exceptional Fuel Economy
  • Extreme Temperature Performance
  • Oil Breakdown Resistance for Long Oil Life
So look at the specs...
  • API: CK-4, CJ-4, CI-4 PLUS, CI-4, CH-4
  • ACEA E9; JASO DH-2; Cummins CES 20086; Volvo VDS-4.5; Detroit Fluid Specification (DFS) 93K222, Caterpillar ECF-2/ECF-3, MAN M3575, JASO MA/MA2, Allison TES 439, MB-Approval 228.31
And what shell names t6.
SHELL ROTELLA T6 FULL SYNTHETIC DIESEL OIL
It doesn't mean you can't use it in a car, but it is technically a diesel oil. Read the page on t6, the oil was designed to battle low ash and soot as well things that happen in modern diesels. Many people use it in cars and motor cycles and other stuff as well. Do you see any Ram specs on your page?
dexter
Banned
It says Dodge.
Can you provide a link for what you are quoting?
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
GAL $20!
PRODUCT DETAILS
Part No. 550046264
Product Features:
Do you have a ****** Oil Sample so we can get a look at the additive package?
GottaBeKD
CA
Its the oil of choice for lots of diesels. I've used it VW, Benz, BMW. Just realized I've owned a few German cars.
Sent from my SM-G955W using Tapatalk
dexter
Banned
Are you saying Beasts report is redline? Are you saying a reading of 350ish Mag is from gasoline? Why wouldn't it be in every other redline uoa?
Blackstone is saying that in their report explanation.
On the link on your page t6 performed worse on the sheet. Look at the results page.
Fig. 7 - Cummins 6.7L ISB Iron Wear Rate by Oil Type
dexter
Banned
Read the words and Chart 6. - Top half wear, bottom additives found.
"so even with the lower iron, we can’t say it was better overall than the others"
So this one is for gas engines, if it says multi vehicle on the bottle.
Likely a very good choice to run, I have no issues. Some reports on the t6 page helping lifter tick, worth a shot.
