Bluesmoke91
2nd GEN Site Mod
- Joined
- Nov 26, 2010
- Posts
- 3,161
- Reaction score
- 240
- Location
- Baldwin Park, California
- Ram Year
- 2007
- Engine
- Hemi 5.7
alright so over the last several months i have had to swap the middle light bulb on the left tail light at least 4 times because after a while it would fry..each time i would get the "light out" warning and once the bulb was replaced, it would go away (nothing unusual there obviously)...recently, the bulb didn't go out but i got the warning again, i checked and with the headlights turned on, all bulbs all the way around the truck were fine but once the brake is pushed, the same problematic bulb stays lit but does not get brighter like it should with the brake being pushed...i took out the bulb and put it back in, everything returned to normal..i just got back from an errand right now and its doing the same exact thing when the brake is pressed...any ideas what could be causing this? im thinking of replacing the light circuit board.
