Tapping into overhead console
davepen
W. St. Paul, MN
6.7L CTD
Hello all. I'd like to tap into my overhead console (2010 2500 CTD) to power a Garmin GPS mounted next to the RVM.
Can I do this easily, and if so, what should I do?
Thanks!
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
I know there is a way to find power in the overhead console.
I will try to find a wiring diagram.
You can always get power down by the radio, from the cigarette lighter, then run the wire up the "A" pillar on the passenger side, disconnect the Negative Post on the battery first.
Then drop a couple inches of the overhead liner over to the overhead console
This is a few years newer than yours, but the wiring colors should be the same
look at post #16
