Tcm communication error, Vehicle Not In Park
UGADAWG
Georgia
2014 ram 1500 5.7. Showing Vehicle not in park, connected my scanner up and it's saying communication error with tcm. All the while, getting a throttle body code that I can't get to go off. Replaced throttle body and sensors but it just won't relearn. Any ideas??
CalDad14
Calgary, Alberta, Canada
2017 Ram 1500 Crew Cab, 4x4, 6-speed, short bed, 392gears
Just thinking out loud....... if it was saying "communucation error with tcm". Why were you confident w/the TB code that was detected? Also, why are you 100% that the fix for said "TB code that I can't get to go off" is the actual fix?
1. Check/clean/use dielectric grease on any & all connections that you can get to in regards to referenced components.
2. Test the same scanner on a vehicle that doesn't have any "dtc's" showing, see what it reports.
3. Get a hold of a different code reader/scanner(if possible) and compare notes.
Good luck.
