badfish888
- Jun 27, 2010
- 1,092
- 89
- Location
- Va beach
- 2012 hemi express
- 5.7L Hemi
well, after 120k i have a tick on start up. Only it doesnt go away when warm. At 50-60k i did the pass side manifold bolts. Sound was slightly different and you could easily tell by the loose heat shield i popped some bolts. The other day i went through a car wash bay to get rid of all the salt on my truck. I sprayed off everything including under the truck. When I started it to leave it was the first time i heard it. Drove 15 miles home. Sounded the same. What i was hoping was maybe i hit the manifold with cold water and it warped and cracked. But i took off the fender liner and the heat shield is tight. And i couldt see a leak. Its hrd to tell if its coming from the manifold or the head. But what are the odds i siezed a lifter it the exact same time of the car wash. I ordered a new manifold, bolts, and mopar gasket. $170 on rock auto for everything. If that doesn’t fix it im going to hve to look into the lifters/cam. If anyone has done this and replaced everything with factory parts. If you could offer some insight and appx cost for everything it would be super helpful. The govt shutdown did not help my finances at all. Im hoping the $170 fixes it. I over maintain everything i own which would only make it worse if she ate the cam/lifters
