Time For A Change
Discussion in 'Engine & Performance' started by MADDOG, Jun 28, 2017.
Sponsored By: Moe's Performance
  1. MADDOG
    MADDOG Super Moderator Staff Member
    7,457
    1,985
    Dec 26, 2011
    Oregon
    Ram Year:
    Engine:
    Cummins 6.7L Turbo Diesel
    After a short drive yesterday afternoon all I can say is... DAMN!!!
    It's a totally different truck. Throttle response, power, shifting, sound...it's all bad ass.
    I'll give it a good test drive today and try to get some vids to post up as well.
    smiley likes this.
  2. The DodgeFather
    The DodgeFather Senior Member
    33
    248
    96
    Feb 12, 2017
    Ram Year:
    Engine:
    6.7
    I'm glad you chose to stay with Ram instead of walk away . Congrats on the new again truck .
  3. Tyrant
    Tyrant Senior Member
    291
    111
    Jan 1, 2012
    Ram Year:
    '12CC / '15RCSB
    Engine:
    Love your way of thinking! :favorites13:
  4. MADDOG
    7,457
    1,985
    Dec 26, 2011
    Oregon
    Ram Year:
    Engine:
  5. MADDOG
    7,457
    1,985
    Dec 26, 2011
    Oregon
    Ram Year:
    Engine:
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Devin1349, smiley and CTD like this.
  6. MADDOG
    7,457
    1,985
    Dec 26, 2011
    Oregon
    Ram Year:
    Engine:
    [​IMG]
    [​IMG]
    [​IMG]
    CTD likes this.
  7. MADDOG
    7,457
    1,985
    Dec 26, 2011
    Oregon
    Ram Year:
    Engine:
    4 tunes available by switch:
    1. Mild upgrade - 30HP
    2. Tow tune - About 50 HP but more about trans tuning, exhaust brake and Tow/Haul mode settings
    3. Race tune - Rollin' coal now at around 80HP. WOT generates some tire slip at 2nd to 3rd gear change. I can see the need for a BDS transmission upgrade soon.
    4. Not sure what to call this one but it's supposedly 120HP and I'm gonna try it today. Maybe when I'm done I'll have a name for it. :)
    The Edge CTS 2 tuner has a lot of cool features that I am just beginning to explore. Yesterday I configured the gauge package to my liking. Outside gauges, in clockwise direction, from upper right are:
    1. Throttle pressure percenage
    2. Torque output
    3. Transmission fluid temperature
    4. Battery voltage
    5. Transmission gear indicator and torque converter lock status
    6. Engine coolant temperature
    The center gauge set up, from top to bottom, is:
    1. Engine exhaust gas temperature
    2. Boost
    3. Speedometer
    I calibrated the CTS with my tire size and the truck's PCM shows the speed with no changes. I verified I have a 1 MPH difference (slower) on the OEM gauge vs. the CTS gauge. Triple verified by using an independent GPS app. No change in deviation observed prior to doing the mods.
    I may have a chance to measure unloaded highway MPG later this next week so will post up results. Best to date unloaded highway MPG is 21.5 and mixed is 17.5 MPG.
    CTD likes this.
  8. CTD
    CTD Senior Member
    166
    77
    Sep 29, 2015
    Southwest, VA
    Ram Year:
    Engine:
    I remember when I tuned my 14. I could not even believe I was setting in the same truck. My stock 2004 5.9 HO Cummins would run circles around my 14 in stock form. Just the sound and not having to smell that cat piss coming out of the exhaust alone made it all worth it me. Also I was not to keen on my Cummins breathing it's own farts.
    I really wish I had not sold mine but I had a bad performance addiction, that was costing me far to much money haha. That and I did not really tow enough to require a diesel.
    I'm assuming you went with EFI live. Who's tuning did you go with?
    Has far as the trans goes, the 68 Rfe tends to like to burn those overdrive clutches with the WOT downshifts on the highways. Has long has you don't run over a 60hp tune, manually down shift before passing on the highway and don't do boosted launches. They tend to hold up just fine with good trans tuning. It really all come's down to the right foot more than it does what tune your running, on how long your trans holds up.
    You probably won't see a huge difference in the mileage, you may gain 1-2mpg. Even though the DPF system is a POS IMO they do have the fuel mileage pretty down pat compared to per def models. The higher hp tunes usually give the best mileage due to the advanced timing.
    Congrats on the new ride. I'm sure it feels like one after that couple hundred pounds of headache fell off the truck. :happy107:
  9. MADDOG
    7,457
    1,985
    Dec 26, 2011
    Oregon
    Ram Year:
    Engine:
    Yes, I went with EFI Live. I have the name of the tuner here somewhere.
    Thanks for the tips on managing the 68RFE under a tune package.
  10. huntergreen
    huntergreen Senior Member
    60
    2,315
    839
    Jan 5, 2011
    Ram Year:
    Engine:
    i am a bit green with envy. if i could delete in jersey, i would have the cummins also. enjoy the "new" motor !
Share This Page
