dpm6836
08 4.7 with 213k. Having a bad clacking/knocking noise. I believed it was the timing chain. A local mechanic did too. I broke it down and noticed slack in the cam chains. When at TDC the slack is in driver side chain (note orange plastic dowel). When I rotate one rotation the slack is in the passenger side Chain.
Should I just replace all timing chains, gears, etc.? The tensioners seem to be extended quite a bit. Any other advice someone can give me?
