No issuesI have a 2010 Ram 1500 TRX4 5.7. Looking to put a leveling kit on and go from 265 to 285. What issues will I be running into and do I need bigger rims or will the stock work?
After the size change mine is off by less than a MPH against me.What about speedometer settings? Will they need adjusted?
Its not a set amount.. If its off by 1mph at say 20mph it may be off by by 4mph at 50mph for example... Your MPG and odometer will also be no longer correct.After the size change mine is off by less than a MPH against me.
