looks like previous owner pressed in longer studs so he could run a spacer under that mount and then "washered up the slack" to sell it. Not only is it a bad way to lift, its pretty hack.
you need, at minimum, new "strut" mounts as after someone has ****** with stuff like that I wouldn't want to reuse.
for the rear, the 1211 are great and will put you up 0.75 inches above stock. The coils unloaded are shorter than stock but do not sag when mounted to your vehicle.
Since your in a bad situation on the front I would either do new quick strut or atleast new mounts with Bilstein 5100s. No idea if you want a lift but the 5100's give you options. If your not trying to level, set at the middle setting 1.4" might be a good place to start with the 1211s in back as they are a bit firmer and adding some preload on the front will help as its what i'm going through right now.
edit: Not sure if you can tell but have the front coils been cut, if not i'm sure they will be fine to run, or junk yard for another set if you think they are compromised. There are no vendor for new coils only. So unless you quick strut or junk yard the options are much pricer like icons or fox.
