Torsion key question
Nogoal9932
Hey guys. I have an 05 4wd 1500. Its sitting level right now with the stock torsion keys cranked all the way up.
My question is this: if I buy the aftermarket keys that say 1-3 inch lift, is this on top of my already existing ride height? Or will buying these basically be the same height as cranking the torsion bars all the way. Bottom line: will I achieve any more lift with aftermarket keys compared to my current set up of cranked torsion bar w original keys.
Thanks all.
VolsRam
Franklin, TN
HEMI 5.7
New keys would not add lift on top of the stock keys that you have cranked as you will have to take those off to put the new ones on. As for the question about whether or not it provides additional potential lift, I am not sure. Hopefully someone else will be able to chime in on that.
