Hardracer
- Jun 11, 2017
- 360
- 314
- 2010 1500 laramie 4x4 crew cab
- Hemi 5.7
What does the module plug into?the bcm?
I have weird things happen once in awhile that I later found out it is all tied to the bcm ...horn randomly going off(I thought was recall done in the column),radio changing stations,2 master door switches half failed...all 3 of these were exact symptoms describe to a failing bcm(on the other forum I read)havent changed it though....just radio still acts up now and then.
Someone more knowledgeable about this please chime in....might be the OPs problem.
I seem to recall when I replaced all 4 sensors that there were 2 diff. mhz for the rams of diff.years when I ordered but don't quote me on that...I think the 433 is correct for his.
3 of my sensors were set and the 4th didn't read..the guy said drive it as he told you...I didnt get out the parking lot and it was working.learned I guess.my truck is older so I dont even know if it has any the same stuff(which it doesnt)as the newer models.
