Traction Controle
Cormier3288
Upstate NY
2011 Outdoorsman
5.7-liter HEMI
Hows it going everyone. I couldn't decide where the best place to post this was so I settled on here.
I have a 2011 Outdoorsman 1500 Regular Cab. The other day in Northern NY we got a lot of snow. I was out playing in it and had turned my traction control off. After drifting and doing doughnuts for a while the light on the right side of my dash(that usually flashes when traction control kicks in) stayed on for a while. Does anyone know why? Also sometimes when I have traction control off (light on the left side indicates it's off) sometimes the right light will flash and my traction control will still kick in. Is that normal?
im sure there is a thread about this. But i couldn't find it. So my appologies if it's a duplicate thread.
jlb
MT
CTD
Turning the traction control "off" doesn't actually turn it off. It only changes the threshold at which it kicks in. I pulled my ABS fuse for this very reason, plus I hate BS, I mean ABS.
14hemiexpress
6.4l
I'm not sure witch years this apples to but if you have it locked into 4wd you can press and hold trac button for about 10 seconds and it will shut esc and traction off. It doesn't work on 2wd trucks.
iam_canadian22
northern ontario
It works in 2wd on older models, my buddy can do it in his 09, im not sure what year they stopped making it work in 2wd in, give it a shot to see, press and hold the traction off for ten seconds and you should here a chime along with a traction dissabled message,
Grad12
v6 3.6
Is holding it for 10 seconds a permanent off or does it come back on when you start up the truck again?
14hemiexpress
6.4l
It resets if you shut the truck off and in my case if i switch it back to 2wd it'll turn back on.
cgeorgemo
Joplin, MO
3.6 Pentastar
There is a different light for stability control that looks like the one for traction control. It will come on when you are sliding around.
pickupman66
Tennessee
I have a 2009 laramie 4x4. in 2wd holing the ESP button for 10 seconds did NOT do anything diferent than just pushing the button. Nor did 15 seconds. do I need to be in 4 high?
iam_canadian22
northern ontario
Ya any 4wd setting will work, and mine does it automatically in low
iam_canadian22
northern ontario
Do you have light on on the dash? I keep debating doing this too as i hate abs and stability control, i find when you learned to drive without them they are more of a pain then they are helpful
jlb
MT
CTD
Ya, two lights, ABS, and the squiggly car light. It isn't really an issue if you know why they are there though. I pretty much forget about them while driving, and if you ever loan your truck out, popping the fuse back in is easy. I even store the fuse I pulled IN the fuse box lol.
Mr. Crowley
Corpus Christi TX
2011 2500 4x4 Crew Cab
5.7Hemi
My 2011 2500 doesn't have a traction control button anywhere. I assume this means it doesn't have traction control.
Doesn't seem to act like it does anyways...and I'm happy with that
loveracing1988
Clarkston, MI
Mine doesnt come back on, lots of highway miles with it completely off
It does, you just don't know it. It won't shut the light off or notify you in any way. Next time it snows floor it so the tires are spinning faster than 45 mph and it will kick back on if it sees you going sideways at all.
Orca
