ramfan96
- Sep 3, 2013
- 9
- 0
- 1996
- magnum 5.2
96 ram 1500 5.2 4x4 with 46re tranny. wasnt shifting out of first so i replaced the governor solenoid and sensor. shifted great for about 10 mins before the tranny overheated and smoke was billowing out of the dipstick tube. i deleted the check valve in the cooler line then figured out the cooler was clogged. i unclogged the cooler. truck seemed to be fine after that except now it will not shift into overdrive at all and seems to be gear hunting slightly when in second. i dont wanna pull the pan again unless i have to itd be the 4th time... i was thinking of using sea foam tranny fix or lucas transmission fix to see if that helps. any other ideas of what i could have ruined when i overheated it?
