Trans and Diff Capacities
ORacer
6.7 liter Cummins Diesel
I have a 2007 Dodge Ram 2500, 2 WD with 6.7 liter Cummins and 6 speed MANUAL transmission. I have owned it since 2009 and it still has only 45,000 miles. I have changed the engine oil regularly also fuel and oil filters.
Time to change transmission and differential fluids. I have looked through the owners manual and cannot find the fill capacity for the trans and diff?
RE: 6 speed manual trans - What is the capacity and can it really use ATF??
Any recommendations on best oil and type to use?
RE: Diff: The manual lists gear lube required, what is the capacity and also any recommendation on the best oil and type to use?
Harley Harrold
USAF Ret. 36+ years service
Mississippi
5.7L HEMI
I hope this helps.
FLUID CAPACITIES
DESCRIPTION SPECIFICATION
FUEL TANK
1500 Short Box 98 L (26 gal.)*
2500/3500 Short Box 128L (34 gal.)*
All Long Box 132 L (35 gal.)*
ENGINE OIL WITH FILTER
3.7L 4.7 L (5.0 qts.)
4.7L 5.6 L (6.0 qts.)
5.7L 6.6 L (7.0 qts.)
5.9L DIESEL 11.4 L (12.0 qts.)
8.3L - Oil Service Quantity 8.2L (8.75 qts.)
8.3L - Engine Overhaul Quantity 9.4L (10.0 qts.)
COOLING SYSTEM
3.7L 15.4 L (16.2 qts.)**
4.7L 15.4 L (16.2 qts.)**
5.7L 15.4L (16.2 qts.)**
5.9L Diesel Engine 28L (29.5 qts.)**
8.3L 15.1L (18 qts.)
POWER STEERING
Power steering fluid capacities are dependent on engine/chassis options as well as steering gear/cooler options.
Depending on type and size of internal cooler, length and inside diameter of cooler lines, or use of an auxiliary
cooler, these capacities may vary. Refer to 19, Steering for proper fill and bleed procedures.
AUTOMATIC TRANSMISSION
Service Fill - 42RLE 3.8L (4.0 qts)
Overhaul Fill - 42RLE 8.3L (17.6 pts)L
Service Fill - 45RFE/545RFE
4X2 - 5.2 L (11.0 pts.)
4X4 - 6.2 L (13.0 pts.)
Overhaul - 45RFE/545RFE 14-16 L (29-33 pts.) L
Service Fill - 48RE 3.8 L (4.0 qts.)
Overhaul - 48RE 14-16L (29-33 pts.) L
L Dry fill capacity. Depending on type and size of internal cooler, length and inside diameter of cooler lines, or
use of an auxiliary cooler, these figures may vary. (Refer to 21 - TRANSMISSION/AUTOMATIC/FLUID -
STANDARD PROCEDURE)
MANUAL TRANSMISSION
DIESEL ENGINE - G56 5.6 L (12 pts.)
5.7L ENGINE - G56 4.7 L (10 pts.)
GETRAG 238 2.2 L (4.6 pts.)
TREMEC T-56 2.27 L (4.8 pts.)
TRANSFER CASE
NV241 GENII 1.6 L (3.4 pts.)
NV243 1.6 L (3.4 pts.)
DR LUBRICATION & MAINTENANCE 0 - 9
NV244 GENII 1.6 L (3.4 pts.)
NV271 1.89 L (4.0 pts.)
NV273 1.89 L (4.0 pts.)
FRONT AXLE ± .03 L (1 oz)
C205FD 1.6 L (56 oz.)
9 1/4 AA 2.2 L (74 oz.)
9 1/4 AA EL 2.0 L (6.8 oz.)
REAR AXLE ± .03 L (1 oz)
9 1/4 2.1 L (72 oz.) ***
10 1/2 AA 2.5 L (85 oz.)
10 1/2 AA EL 2.5 L (85 oz.)
11 1/2 AA Open 4.2 L (142 oz.)
11 1/2 AA Trac-Rite 4.0 L (135 oz.)
248RBI (DANA 60) 2.8 L (46 oz.) ****
*** With Trac-Lok add 118 ml (4 oz.) of Limited Slip Additive.
**** Add 147 ml (5 oz.) of Limited Slip Additive
** Includes 0.9L (1.0 qts.) for coolant reservoir.
*Nominal refill capacities are shown. A variation may be observed from vehicle to vehicle due to manufacturing
tolerance and refill procedure.:peace:
O
ORacer
Sorry Harley, I don't get it...
I have a 2007 2500 Ram crew cab, short bed, 6.7 liter Cummins Diesel, 6 speed manual transmission and 2 wheel drive.
I can't make heads or tails of the list you gave me,
Any clarification would be appreciated
RonJon '06
Southern Minnesota
You could try posting in the Cummins Diesel section, might get more responses there. :welcome:
