Trans. Filter Question
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
So I'm going to be changing the trans. fluid in my dad's truck sometime this spring/summer and was looking at filters. There are 3 different filters for the 45RFE: two pan filters, one for a deep and one for a shallow pan and a spin on filter. Looks like the "flat" filters are correct, but which one? Are there different pan depths for the towing vs. non-towing package trucks that I didn't know about?
The deep filter kit is for the 4wd and shallow is for 2wd. I used the wix kit and changed all 17 or 18 quarts of oil. You can do a DIY flush by removing the oil return line and pumping the old fluid out. Once it starts spitting, pull the pan and change filters. Replace pan and fill 7 quarts of new fluid. Then start the truck and keep pumping the old oil out while adding new oil through the dip stick. Do that until you've used up all 17 quarts. Then check your levels and top off if needed.
dodge dude94
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Gotcha. That makes perfect sense actually. I don't like messing with cooler lines so I'll just be changing the pan and filter. Thank you!!
JustinRam1500
