Transfer case oil change question
Discussion in 'Tech Info' started by snakepitt1, Oct 28, 2016.
  1. snakepitt1
    snakepitt1 Junior Member
    56
    14
    Oct 20, 2016
    Lake View, Alabama
    Ram Year:
    2007 1500 4x4
    Engine:
    2007 Ram 1500 4x4
    How do you drain and change the fluid in the transfer case?
    What type of fluid is required?
    How much will be required?
    Are there any filters or gaskets required?
    usaf2006 likes this.
  2. usaf2006
    usaf2006 Senior Member
    3,818
    1,022
    Mar 28, 2014
    Augusta, GA
    Ram Year:
    Engine:
    I added a picture of my transfer case for reference.
    You can see the bottom plug, which is the drain plug.
    Take the top one out, then remove the drain plug.
    Put the bottom plug back in, and fill with 2 quarts of atf+4 auto transmission fluid.
    No gaskets or filters required.
  3. JPT
    JPT Senior Member
    39
    962
    240
    Feb 22, 2014
    NY
    Ram Year:
    2015 Big Horn
    Engine:
    MOST IMPORTANT ADVICE... ALWAYS fill plug before drain... Otherwise you may find yourself in a situation where you can't open the fill plug.
    I have seen people fill thing from the vent tube hole in a pinch, but since it is on top, it is a PITA to do...
  4. snakepitt1
    56
    14
    Oct 20, 2016
    Lake View, Alabama
    Ram Year:
    2007 1500 4x4
    Engine:
    Perfect, thanks. I have no way of knowing when or if he fluid has ever been changed in the transfer case, so I will change it and start my own baseline for future services on my truck.
  5. usaf2006
    3,818
    1,022
    Mar 28, 2014
    Augusta, GA
    Ram Year:
    Engine:
    Good to know. I think it's only recommended to change it every 75k miles
Share This Page
