- Sep 25, 2019
- 2,609
- 2,313
- Location
- Rochester, NY
- 2019
- Hemi 5.7
I read the whole work order, there was a recall on the dip stick that it looked like they didn't have in stock, you had a transmission over temp (P0218-00), that caused a gear 6 shift incorrect (P0729-00) ,and a gear shift 5 incorrect (P0735), and a hydraulic pressure sensor (P0933) ,Payload limited exceeded (C15DA) this all looks like a failure that started with a over temp fault, was ATF fluid spilling out of the dip stick tube?, with all of the new OBD systems in place all of these set a hard code that the dealer was able to retrieve, with that payload limit exceeded its going to be hard to get it warranted.
