When making BIG power any WOT, passing gear type of downshifts are bad for any brand/year of auto transmission's.
The Sharadon valve body all started with my truck. Needed to figure a way to get the truck to shift faster and really had no interest in marketing them. After building and testing mine a few of the 03 guy's that swapped to 4.56 gears kept hitting the rev limiter between shifts so I sent a couple out for testing and low and behold their transmission's shifted faster which kept them from hitting the limiter. HEMI450 can attest to this since he was one of the first ones to test one out at the track and the beginning of marketing the valve body. So yes, the Sharadon valve body does give you faster upshifts and no, the accumulator springs are still used. BTW, just getting the fact's out on that rumor.
Then I had an issue with the transmission all together. There was no way to keep a stock transmission under my truck so instead of knocking the power down I decided to build a better transmission. It's still a learning process. I helped with the design of the Stage II while Sharadon can take full credit for the Stage III and I went on from there to make a Stage IV which is still in testing in my truck.
I was the first to use the 68RFE diesel clutches in a 545RFE after finding how well the Alto Red's and Koleen steels DIDn'T work for certain clutch packs. There's also a 4 page write up with pic's in a past 2008 Mopar Muscle Magazine showing exactly how this is done. Show's you what parts where machined and the extra clutches that were added. I'm sure there are transmission shops that have copied the build and even added in their own mod's, but machining plates and adding clutches have been around for as long as I can remember. IMO that just because the 68RFE clutches can hold 750 ft/lbs tq for a diesel doesn't mean they'll hold 750 ft/lbs tq in a gas motor. Clutch application at RPM being the difference.
I do plenty of R&D with the 545. Currently my office is in shambles with small transmission parts scattered everywhere from solenoids, pressure regulators, clutches, steels, valve bodies, etc, all having certain mod's done to them.
When making power I think transmission tuning is a joke unless you can data log as to what is being done and why no tuner ie whitelightning or hemifever know's better to mess with mine. I can data log with a PCS standalone, but even still there's really no good tune you can create without premature failures either, which brings me back to beefing up the mechanical side of things inside the transmission. I'm currently working on my 15th 545 revision with #16 and 17 right behind it. Now I just need to get my butt to the track lol. I'm making close to 850hp/tq and going back to some of the mod's that I had on my 9th and 10th revisions which both looked good after 100 track passes. #12 and 13 didn't fair so well with less than 20 each before they both failed. Figure if I can make a transmission hold up to 200 of my passes that transmission should hold up to a good beating from the guy's making 500hp/tq.
Also, I'll be glad to answer any and all your questions you have about the myth's and rumor's of the 545. Please don't PM me. I'd rather keep it on an open forum and maybe even start a new topic.
Some mod's to my 4x4 Ram truck....6.1 based 392, Paxton 1500 blower with 2 small stages of n2o, custom ground Cammotion camshaft, 3800 Edge Racing converter, 3.92 gears, SMT6 with Superchips 3815 for tuning and a bunch of other stuff.
1.48 60' 6.87@98 1/8 11.03@118 1/4
