trim ring suggestion
shortbus317
Las Vegas, nv
Looking for a replacement trim ring to go around the shifter (floor shifter). Mine is chrome and has the pleasant ability to turn into a flashbang in the vegas sunlight when I turn the right direction.
I imagine that its plastic, so I am not sure if using hydrocloric acid or easy-off is going to do the trick or not, and would prefer something that looks better than my impatience will allow. The only aftermarket ones I seem to see are all chrome as well.
SitKneelBend
St. Louis
3.6 Pentastar
You might have some luck with a 3m green or red scrubbing pad to dull the chrome.
DAK2
I used plastidip smoke spray on mine, it also eliminated the ghost green led light that reflected off the pass. side window at night (led light upper console that shined down to center console)
