trouble code list
Discussion in 'Tech Info' started by ramhunter9, Jun 27, 2010.
Thread Status:
Not open for further replies.
  1. ramhunter9
    ramhunter9 Supporting Member
    24,508
    885
    Jun 25, 2010
    Ram Year:
    Engine:
    P-Star Jeep Wrangler
    P0000 - P0099
    P0001 Fuel Volume Regulator Ctrl Circ/Open
    P0002 Fuel Volume Regulator Ctrl Circ Range/Perf
    P0003 Fuel Volume Regulator Ctrl Circ Low
    P0004 Fuel Volume Regulator Ctrl Circ Hi
    P0005 Fuel Shutoff Valve A Ctrl Circ/Open
    P0006 Fuel Shutoff Valve A Ctrl Circ Low
    P0007 Fuel Shutoff Valve A Ctrl Circ Hi
    P0008 Engine Pos Sys Perf Bank1
    P0009 Engine Pos Sys Perf Bank2
    P0010 A Camshaft Pos Actuator Circ Bank1
    P0011 A Camshaft Pos-Timing Over-Advanced or Sys Perf Bank1
    P0012 A Camshaft Pos-Timing Over-Retarded Bank1
    P0013 B Camshaft Pos-Actuator Circ Bank1
    P0014 B Camshaft Pos-Timing Over-Advanced or Sys Perf Bank1
    P0015 B Camshaft Pos-Timing Over-Retarded Bank1
    P0016 Crank/Camshaft Mis-align/sync
    P0017 Crank Pos-Camshaft Pos Correlation Bank1 Sens B
    P0018 Crank Pos-Camshaft Pos Correlation Bank2 Sens A
    P0019 Crank Pos-Camshaft Pos Correlation Bank2 Sens B
    P0020 A Camshaft Pos Actuator Circ Bank2
    P0021 A Camshaft Pos-Timing Over-Advanced or Sys Perf Bank2
    P0022 A Camshaft Pos-Timing Over-Retarded Bank2
    P0023 B Camshaft Pos-Actuator Circ Bank2
    P0024 B Camshaft Pos-Timing Over-Advanced or Sys Perf Bank2
    P0025 B Camshaft Pos-Timing Over-Retarded Bank2
    P0026 Intake Valve Ctrl Solenoid Circ Range/Perf Bank1
    P0027 Exhaust Valve Ctrl Solenoid Circ Range/Perf Bank1
    P0028 Intake Valve Ctrl Solenoid Circ Range/Perf Bank2
    P0029 Exhaust Valve Ctrl Solenoid Circ Range/Perf Bank2
    P0030 1/1 02 Sens Heater Relay Malfunction
    P0031 HO2S Heater Ctrl Circ Low Bank1 Sens1
    P0032 HO2S Heater Ctrl Circ Hi Bank1 Sens1
    P0033 Turbo Charger Bypass Valve Ctrl Circ
    P0034 Turbo Charger Bypass Valve Ctrl Circ Low
    P0035 Turbo Charger Bypass Valve Ctrl Circ Hi
    P0036 1/2 02 Sens Heater Relay Malfunction
    P0037 HO2S Heater Ctrl Circ Low Bank1 Sens2
    P0038 HO2S Heater Ctrl Circ Hi Bank1 Sens2
    P0039 T/Super Charger Bypass Valve Ctrl Circ Range/Perf
    P0040 O2 Sens Signals Swapped Bank1 Sens1/ Bank2 Sens1
    P0041 O2 Sens Signals Swapped Bank1 Sens2/ Bank2 Sens2
    P0042 HO2S Heater Ctrl Circ Bank1 Sens3
    P0043 HO2S Heater Ctrl Circ Low Bank1 Sens3
    P0044 HO2S Heater Ctrl Circ Hi Bank1 Sens3
    P0045 T/Super Charger Boost Ctrl Solenoid Circ/Open
    P0046 T/Super Charger Boost Ctrl Solenoid Circ Range/Perf
    P0047 T/Super Charger Boost Ctrl Solenoid Circ Low
    P0048 T/Super Charger Boost Ctrl Solenoid Circ Hi
    P0049 T/Super Charger Turbine Overspeed
    P0050 HO2S Heater Ctrl Circ Bank2 Sens1
    P0051 HO2S Heater Ctrl Circ Low Bank2 Sens1
    P0052 HO2S Heater Ctrl Circ Hi Bank2 Sens1
    P0053 HO2S Heater Resistance Bank1 Sens1
    P0054 HO2S Heater Resistance Bank1 Sens2
    P0055 HO2S Heater Resistance Bank1 Sens3
    P0056 HO2S Heater Ctrl Circ Bank2 Sens2
    P0057 HO2S Heater Ctrl Circ Low Bank2 Sens2
    P0058 HO2S Heater Ctrl Circ Hi Bank2 Sens2
    P0059 HO2S Heater Resistance Bank2 Sens1
    P0060 HO2S Heater Resistance Bank2 Sens2
    P0061 HO2S Heater Resistance Bank2 Sens3
    P0062 HO2S Heater Ctrl Circ Bank2 Sens3
    P0063 HO2S Heater Ctrl Circ Low Bank2 Sens3
    P0064 HO2S Heater Ctrl Circ Hi Bank2 Sens3
    P0065 Air Assisted Injector Ctrl Range/Perf
    P0066 Air Assisted Injector Ctrl Circ or Circ Low
    P0067 Air Assisted Injector Ctrl Circ Hi
    P0068 MAP/MAF-Throttle Pos Correlation
    P0069 MAP-Barometric Press Correlation
    P0070 Ambient Air Temp Sens Circ
    P0071 Ambient Temp Sens Perf
    P0072 Ambient Temp Sens Low
    P0073 Ambient Temp Sens Hi
    P0074 Ambient Air Temp Sens Circ Interm
    P0075 Intake Valve Ctrl Solenoid Circ Bank1
    P0076 Intake Valve Ctrl Solenoid Circ Low Bank1
    P0077 Intake Valve Ctrl Solenoid Circ Hi Bank1
    P0078 Exhaust Valve Ctrl Solenoid Circ Bank1
    P0079 Exhaust Valve Ctrl Solenoid Circ Low Bank1
    P0080 Exhaust Valve Ctrl Solenoid Circ Hi Bank1
    P0081 Intake Valve Ctrl Solenoid Circ Bank2
    P0082 Intake Valve Ctrl Solenoid Circ Low Bank2
    P0083 Intake Valve Ctrl Solenoid Circ Hi Bank2
    P0084 Exhaust Valve Ctrl Solenoid Circ Bank2
    P0085 Exhaust Valve Ctrl Solenoid Circ Low Bank2
    P0086 Exhaust Valve Ctrl Solenoid Circ Hi Bank2
    P0087 Fuel Rail/Sys Press-Too Low
    P0088 Fuel Rail Press Hi
    P0089 Fuel Press Regulator 1 Perf
    P0090 Fuel Press Regulator 1 Ctrl Circ
    P0091 Fuel Press Regulator 1 Ctrl Circ Low
    P0092 Fuel Press Regulator 1 Ctrl Circ Hi
    P0093 Fuel Sys Leak Detected-Large Leak
    P0094 Fuel Sys Leak Detected-Small Leak
    P0095 Intake Air Temp Sens2 Circ
    P0096 Intake Air Temp Sens2 Circ Range/Perf
    P0097 Intake Air Temp Sens2 Circ Low
    P0098 Intake Air Temp Sens2 Circ Hi
    P0099 Intake Air Temp Sens2 Circ Interm/Erratic
  2. ramhunter9
    24,508
    885
    Jun 25, 2010
    Ram Year:
    Engine:
    P0100 - P0199
    P0100 Mass or Volume Air Flow Circ
    P0101 MAF Sens Perf
    P0102 MAF Sens Low frequency
    P0103 MAF Sens Hi frequency
    P0104 Mass or Volume Air Flow Circ Interm
    P0105 MAP/Barometric Press Circ
    P0106 Barometric Press Out of Range
    P0107 Map Sens Voltage Too Low
    P0108 Map Sens Voltage Too Hi
    P0109 MAP/Barometric Press Circ Interm
    P0110 Intake Air Temp Sens1 Circ
    P0111 Intake Air Temp Sens Perf
    P0112 Intake Air Temp Sens Voltage Low
    P0113 Intake Air Temp Sens Voltage Hi
    P0114 Intake Air Temp Sens1 Circ Interm
    P0115 Engine Coolant Temp Circ
    P0116 Coolant Temp Sens Perf
    P0117 ECT Sens Voltage Too Low
    P0118 ECT Sens Voltage Too Hi
    P0119 Engine Coolant Temp Circ Interm
    P0120 Throttle/Pedal Pos Sens/Switch A Circ
    P0121 TPS Voltage Does Not Agree with MAP
    P0122 Throttle Pos Sens Voltage Low
    P0123 Throttle Pos Sens Voltage Hi
    P0124 Throttle/Pedal Pos Sens/Switch A Circ Interm
    P0125 Closed Loop Temp Not Reached
    P0126 Insufficient ECT for Stable Operation
    P0127 Intake Air Temp Too Hi
    P0128 Cooling Sys Error / Thermostat Perf
    P0129 Barometric Press Too Low
    P0130 1/1 02 Sens Heater Relay Malfunction
    P0131 1/1 02 Sens Shorted To Ground
    P0132 1/1 O2S Shorted To Voltage
    P0133 1/1 O2S Slow Response
    P0134 1/1 O2S Stays At Center
    P0135 1/1 O2S Heater Failure
    P0136 1/2 02 Sens Heater Relay Malfunction
    P0137 1/2 O2S Shorted To Ground
    P0138 1/2 O2S Shorted To Voltage
    P0139 1/2 O2S Slow Response
    P0140 1/2 O2S Stays At Center
    P0141 1/2 02 Sens Relay
    P0142 O2 Sens Circ Bank1 Sens3
    P0143 1/3 O2S Shorted To Ground
    P0144 1/3 O2S Shorted To Voltage
    P0145 1/3 O2S Slow Response
    P0146 1/3 O2S Stays At Center
    P0147 1/3 02 Sens Heater Failure
    P0148 Fuel Delivery Error
    P0149 Fuel Timing Error
    P0150 O2 Sens Circ Bank2 Sens1
    P0151 2/1 02 Sens Shorted To Ground
    P0152 2/1 02 Sens Shorted To Voltage
    P0153 2/1 02 Sens Slow Response
    P0154 2/1 02 Sens Stays at Center
    P0155 2/1 02 Sens Heater Failure
    P0156 O2 Sens Circ Bank2 Sens2
    P0157 2/2 02 Sens Shorted To Ground
    P0158 2/2 02 Sens Shorted To Voltage
    P0159 2/2 02 Sens Slow Response
    P0160 2/2 02 Sens Stays at Center
    P0161 2/2 02 Sens Heater Failure
    P0162 O2 Sens Circ Bank2 Sens3
    P0163 O2 Sens Circ Low Voltage Bank2 Sens3
    P0164 O2 Sens Circ Hi Voltage Bank2 Sens3
    P0165 Starter Relay Ctrl Circ
    P0166 O2 Sens Circ No Activity Detected Bank2 Sens3
    P0167 O2 Sens Heater Circ Bank2 Sens3
    P0168 Decreased Engine Perf Due to Hi Inj Pump Fuel Temp
    P0169 Water-in-fuel detected for too long
    P0170 Fuel Trim Bank1
    P0171 1/1 Fuel Sys Lean
    P0172 1/1 Fuel Sys Rich
    P0173 Fuel Trim Bank2
    P0174 2/1 Fuel Sys Lean
    P0175 2/1 Fuel Sys Rich
    P0176 Loss of Flex Fuel Calibration Signal
    P0177 Water In Fuel
    P0178 Flex Fuel Sens Volts Too Low
    P0178 Water in Fuel Sens Volts Too Low or
    P0179 Flex Fuel Sens Volts Too Hi
    P0180 CNG Temp Sens Voltage Fail
    P0181 Fuel Inj Pump Failure
    P0182 CNG Temp Sens Voltage Too Low
    P0183 CNG Temp Sens Voltage Too Hi
    P0184 Fuel Temp Sens A Circ Interm
    P0185 Fuel Temp Sens B Circ
    P0186 Fuel Temp Sens B Circ Range/Perf
    P0187 Fuel Temp Sens B Circ Low
    P0188 Fuel Temp Sens B Circ Hi
    P0189 Fuel Temp Sens B Circ Interm
    P0190 Fuel Rail Press Sens Circ
    P0191 Fuel Rail Press Sens Circ Range/Perf
    P0192 Fuel Rail Press Sens Low
    P0193 Fuel Rail Press Sens Hi
    P0194 Fuel Rail Press Sens Circ Interm
    P0195 Engine Oil Temp Sens
    P0196 Engine Oil Temp Sens Range/Perf
    P0197 Engine Oil Temp Sens Low
    P0198 Engine Oil Temp Sens Hi
    P0199 Engine Oil Temp Sens Interm
  3. ramhunter9
    24,508
    885
    Jun 25, 2010
    Ram Year:
    Engine:
    P0200 - P0299
    P0200 Injector Circ/Open
    P0201 Injector #1 Ctrl Circ
    P0202 Injector #2 Ctrl Circ
    P0203 Injector #3 Ctrl Circ
    P0204 Injector #4 Ctrl Circ
    P0205 Injector #5 Ctrl Circ
    P0206 Injector #6 Ctrl Circ
    P0207 Injector #7 Ctrl Circ
    P0208 Injector #8 Ctrl Circ
    P0209 Injector #9 Ctrl Circ
    P0210 Injector #10 Ctrl Circ
    P0211 Injector Circ/Open-Cylinder 11
    P0212 Injector Circ/Open-Cylinder 12
    P0213 Cold Start Injector 1
    P0214 Cold Start Injector 2
    P0215 Fuel Inj Pump Ctrl Circ
    P0216 Fuel Inj Pump Timing Failure
    P0217 Decreased Eng Perf due to Eng Overheat Condition
    P0218 Trans Fluid Over Temp Condition
    P0219 CKP Sens Overspeed Condition
    P0220 APP Sens2 Circ
    P0221 APP Sens2 Circ Perf
    P0222 Idle Validation Signals Both Low
    P0222 APP Sens2 Circ Low Voltage or
    P0223 Idle Validation Signals Both Hi (Above 5Vs)
    P0223 Inj Pulse Width Error (Rise Time Long) or
    P0224 Throttle/Pedal Pos Sens/Switch B Circ Interm
    P0225 APP Sens3 Circ
    P0226 APP Sens3 Circ Perf
    P0227 APP Sens2 Circ Low Voltage
    P0228 APP Sens2 Circ Hi Voltage
    P0229 Throttle/Pedal Pos Sens/Switch C Circ Interm
    P0230 Transfer Pump (Lift Pump) Circ Out Of Range
    P0231 Fuel Pump Feedback Circ Low Voltage
    P0232 Fuel Shut-Off Signal Voltage Too Hi
    P0233 Fuel Pump Sec Circ Interm
    P0234 Turbo Boost Limit Exceeded
    P0235 T/Super Charger Boost Sens A Circ
    P0236 MAP Sens Too Hi Too Long
    P0237 MAP Sens Voltage Too Low
    P0238 MAP Sens Voltage Too Hi
    P0239 T/Super Charger Boost Sens B Circ
    P0240 T/Super Charger Boost Sens B Circ Range/Perf
    P0241 T/Super Charger Boost Sens B Circ Low
    P0242 T/Super Charger Boost Sens B Circ Hi
    P0243 Open or shorted condition detected in the turbocharger Wastegate solenoid Ctrl
    P0244 T/Super Charger Wastegate Solenoid A Range/Perf
    P0245 T/Super Charger Wastegate Solenoid A Low
    P0246 T/Super Charger Wastegate Solenoid A Hi
    P0247 T/Super Charger Wastegate Solenoid B
    P0248 T/Super Charger Wastegate Solenoid B Range/Perf
    P0249 T/Super Charger Wastegate Solenoid B Low
    P0250 T/Super Charger Wastegate Solenoid B Hi
    P0251 Fuel Inj Pump Fuel valve Feedback Circ
    P0252 Fuel Inj Pump Fuel Valve Stuck
    P0253 Fuel Inj Pump Fuel Valve Open Circ
    P0254 Fuel Inj Pump Fuel Valve Current Too Hi
    P0255 Inj Pump Fuel Metering Ctrl A Interm (Cam/Rotor/Injector)
    P0256 Inj Pump Fuel Metering Ctrl B (Cam/Rotor/Injector)
    P0257 Inj Pump Fuel Metering Ctrl B Range/Perf (Cam/Rotor/Injector)
    P0258 Inj Pump Fuel Metering Ctrl B Low (Cam/Rotor/Injector)
    P0259 Inj Pump Fuel Metering Ctrl B Hi (Cam/Rotor/Injector)
    P0260 Inj Pump Fuel Metering Ctrl B Interm (Cam/Rotor/Injector)
    P0261 Cylinder 1 Injector Circ Low
    P0262 Cylinder 1 Injector Circ Hi
    P0263 Cylinder 1 Balance Sys
    P0264 Cylinder 2 Injector Circ Low
    P0265 Cylinder 2 Injector Circ Hi
    P0266 Cylinder 2 Balance Sys
    P0267 Cylinder 3 Injector Circ Low
    P0268 Cylinder 3 Injector Circ Hi
    P0269 Cylinder 3 Balance Sys
    P0270 Cylinder 4 Injector Circ Low
    P0271 Cylinder 4 Injector Circ Hi
    P0272 Cylinder 4 Balance Sys
    P0273 Cylinder 5 Injector Circ Low
    P0274 Cylinder 5 Injector Circ Hi
    P0275 Cylinder 5 Balance Sys
    P0276 Cylinder 6 Injector Circ Low
    P0277 Cylinder 6 Injector Circ Hi
    P0278 Cylinder 6 Balance Sys
    P0279 Cylinder 7 Injector Circ Low
    P0280 Cylinder 7 Injector Circ Hi
    P0281 Cylinder 7 Balance Sys
    P0282 Cylinder 8 Injector Circ Low
    P0283 Cylinder 8 Injector Circ Hi
    P0284 Cylinder 8 Balance Sys
    P0285 Cylinder 9 Injector Circ Low
    P0286 Cylinder 9 Injector Circ Hi
    P0287 Cylinder 9 Contribution/Balance
    P0288 Cylinder 10 Injector Circ Low
    P0289 Cylinder 10 Injector Circ Hi
    P0290 Cylinder 10 Contribution/Balance
    P0291 Cylinder 11 Injector Circ Low
    P0292 Cylinder 11 Injector Circ Hi
    P0293 Cylinder 11 Contribution/Balance
    P0294 Cylinder 12 Injector Circ Low
    P0295 Cylinder 12 Injector Circ Hi
    P0296 Cylinder 12 Contribution/Balance
    P0297 Vehicle Overspeed Condition
    P0298 Engine Oil Over Temp
    P0299 T/Super Charger Underboost
  4. ramhunter9
    24,508
    885
    Jun 25, 2010
    Ram Year:
    Engine:
    P0300 - P0399
    P0300 Multiple Cylinder Misfire
    P0301 Cylinder #1 Misfire
    P0302 Cylinder #2 Misfire
    P0303 Cylinder #3 Misfire
    P0304 Cylinder #4 Misfire
    P0305 Cylinder #5 Misfire
    P0306 Cylinder #6 Misfire
    P0307 Cylinder #7 Misfire
    P0308 Cylinder #8 Misfire
    P0309 Cylinder #9 Misfire
    P0310 Cylinder #10 Misfire
    P0311 Cylinder 11 Misfire Detected
    P0312 Cylinder 12 Misfire Detected
    P0313 Misfire Detected with Low Fuel
    P0314 Single Cylinder Misfire (Cylinder not Specified)
    P0315 Crank Pos Sys Variation Not Learned
    P0316 Engine Misfire Detected on Startup (First 1000 Revs)
    P0317 Rough Road Hardware Not Present
    P0318 Rough Road Sens A Signal Circ
    P0319 Rough Road Sens B
    P0320 No Crank Ref Signal at PCM
    P0321 Ignition/Distributor Engine Speed Input Circ Range/Perf
    P0322 Ignition/Distributor Engine Speed Input Circ No Signal
    P0323 Ignition/Distributor Engine Speed Input Circ Interm
    P0324 Knock Ctrl Sys Error
    P0325 Knock Sens #1 Circ
    P0326 Knock Sens1 Circ Range/Perf Bank1 or Single Sens
    P0327 Knock Sens Noise Channel Low Voltage
    P0328 Knock Sens1 Circ Hi Bank1 or Single Sens
    P0329 Knock Sens1 Circ Input Interm Bank1 or Single Sens
    P0330 Knock Sens #2 Circ
    P0331 Knock Sens2 Circ Range/Perf Bank2
    P0332 Knock Sens2 Circ Low Bank2
    P0333 Knock Sens2 Circ Hi Bank2
    P0334 Knock Sens2 Circ Input Interm Bank2
    P0335 Crank Pos Sens Circ
    P0336 Crank Pos Sens Perf
    P0337 Crank Pos Sens Circ Low
    P0338 Crank Pos Sens Circ Hi
    P0339 Crank Pos Sens Circ Interm
    P0340 No Cam Signal At PCM
    P0341 CMP Sens Signal
    P0342 ESS Voltage Supply Low
    P0343 ESS Voltage Supply Hi
    P0344 Camshaft Pos Sens A Circ Interm Bank1 or Single Sens
    P0345 Camshaft Pos Sens A Circ Bank2
    P0346 Camshaft Pos Sens A Circ Range/Perf Bank2
    P0347 Camshaft Pos Sens A Circ Low Bank2
    P0348 Camshaft Pos Sens A Circ Hi Bank2
    P0349 Camshaft Pos Sens A Circ Interm Bank2
    P0350 Ignition Coil Draws Too Much Current
    P0351 Ignition Coil # 1 Primary Circ
    P0352 Ignition Coil # 2 Primary Circ
    P0353 Ignition Coil # 3 Primary Circ
    P0354 Ignition Coil # 4 Primary Circ
    P0355 Ignition Coil # 5 Primary Circ
    P0356 Ignition Coil # 6 Primary Circ
    P0357 Ignition Coil # 7 Primary Circ
    P0358 Ignition Coil # 8 Primary Circ
    P0359 Ignition Coil I Primary/Sec Circ
    P0360 Ignition Coil J Primary/Sec Circ
    P0361 Ignition Coil K Primary/Sec Circ
    P0362 Ignition Coil L Primary/Sec Circ
    P0363 Misfire Detected-Fueling Disabled
    P0365 Camshaft Pos Sens B Circ Bank1
    P0366 Camshaft Pos Sens B Circ Range/Perf Bank1
    P0367 Camshaft Pos Sens B Circ Low Bank1
    P0368 Camshaft Pos Sens B Circ Hi Bank1
    P0369 Camshaft Pos Sens B Circ Interm Bank1
    P0370 Fuel Inj Pump Speed/Pos Sens Signal Lost
    P0371 Timing Ref Hi Res Signal A Too Many Pulses
    P0372 Timing Ref Hi Res Signal A Too Few Pulses
    P0373 Timing Ref Hi Res Signal A Interm/Erratic Pulses
    P0374 Timing Ref Hi Res Signal A No Pulse
    P0375 Timing Ref Hi Res Signal B
    P0376 Timing Ref Hi Res Signal B Too Many Pulses
    P0377 Timing Ref Hi Res Signal B Too Few Pulses
    P0378 Timing Ref Hi Res Signal B Interm/Erratic Pulses
    P0379 Timing Ref Hi Res Signal B No Pulses
    P0380 Glow Plug Circ Perf
    P0380 Intake Air Heater Relay No. 1 Ctrl Circ or
    P0381 Wait To Start Lamp Inoperative
    P0382 Intake Air Heater Relay No. 2 Ctrl Circ
    P0383 P0384 Reserved by document
    P0385 Crank Pos Sens B Circ
    P0386 Crank Pos Sens B Circ Range/Perf
    P0387 CKP Sens Supply Voltage Too Low
    P0388 CKP Sens Supply Voltage Too Hi
    P0389 Crank Pos Sens B Circ Interm
    P0390 Camshaft Pos Sens B Circ Bank2
    P0391 Camshaft Pos Sens B Circ Range/Perf Bank2
    P0392 Camshaft Pos Sens B Circ Low Bank2
    P0393 Camshaft Pos Sens B Circ Hi Bank2
    P0394 Camshaft Pos Sens B Circ Interm Bank2
  5. ramhunter9
    24,508
    885
    Jun 25, 2010
    Ram Year:
    Engine:
    P0400 - P0499
    P0400 Exhaust Gas Recirculation (EGR) Flow Malfunction
    P0401 EGR Sys Failure
    P0402 EGR Flow Excessive Detected
    P0403 EGR Solenoid Circ
    P0404 EGR Pos Sens Rationality
    P0405 EGR Pos Sens Volts Too Low
    P0406 EGR Pos Sens Volts Too Hi
    P0407 Exhaust Gas Recirculation Sens B Circ Low
    P0408 Exhaust Gas Recirculation Sens B Circ Hi
    P0409 Exhaust Gas Recirculation Sens A Circ
    P0410 AIR Sys
    P0411 Sec Air Inj Sys Incorrect Flow Detected
    P0412 Sec Air Solenoid Circ
    P0413 Sec Air Inj Sys Switching Valve A Circ Open
    P0414 Sec Air Inj Sys Switching Valve A Circ Shorted
    P0415 Sec Air Inj Sys Switching Valve B Circ
    P0416 Sec Air Inj Sys Switching Valve B Circ Open
    P0417 Sec Air Inj Sys Switching Valve B Circ Shorted
    P0418 Sec Air Inj Sys Ctrl A Circ
    P0419 Sec Air Inj Sys Ctrl B Circ
    P0420 1/1 Catalytic Conv Eff
    P0421 Warm Up Catalyst Eff Below Threshold Bank1
    P0422 Main Catalyst Eff Below Threshold Bank1
    P0423 Heated Catalyst Eff Below Threshold Bank1
    P0424 Heated Catalyst Temp Below Threshold Bank1
    P0425 Catalyst Temp Sens Bank1
    P0426 Catalyst Temp Sens Range/Perf Bank1
    P0427 Catalyst Temp Sens Low Bank1
    P0428 Catalyst Temp Sens Hi Bank1
    P0429 Catalyst Heater Ctrl Circ Bank1
    P0430 1/2 Catalytic Conv Eff
    P0431 Warm Up Catalyst Eff Below Threshold Bank2
    P0432 1/2 Catalytic Conv Eff
    P0433 Heated Catalyst Eff Below Threshold Bank2
    P0434 Heated Catalyst Temp Below Threshold Bank2
    P0435 Catalyst Temp Sens Bank2
    P0436 Catalyst Temp Sens Range/Perf Bank2
    P0437 Catalyst Temp Sens Low Bank2
    P0438 Catalyst Temp Sens Hi Bank2
    P0439 Catalyst Heater Ctrl Circ Bank2
    P0440 Evap Sys Perf
    P0441 Evap Purge Flow Monitor
    P0442 Evap Leak Monitor Medium Leak Detected
    P0443 Evap Purge Solenoid Circ
    P0444 Evap Emission Sys Purge Ctrl Valve Circ Open
    P0445 Evap Emission Sys Purge Ctrl Valve Circ Shorted
    P0446 Evap Emissions Vent Valve Perf
    P0447 Evap Emission Sys Vent Ctrl Circ Open
    P0448 Evap Emission Sys Vent Ctrl Circ Shorted
    P0449 Evap Emission Sys Vent Valve/Solenoid Circ
    P0450 Evap Emission Sys Press Sens/Switch
    P0451 Evap Emission Sys Press Sens/Switch Range/Perf
    P0452 Evap Emissions Press Sens Circ Low Volts
    P0453 Evap Emissions Press Sens Circ Hi Volts
    P0454 Evap Emission Sys Press Sens/Switch Interm
    P0455 Evap Leak Monitor Large Leak Detected
    P0456 Evap Leak Monitor Small (0.020) Leak Detected
    P0457 EVAP Emission Sys Leak Detected (fuel cap loose/off)
    P0458 EVAP Emission Sys Purge Ctrl Valve Circ Low
    P0459 EVAP Emission Sys Purge Ctrl Valve Circ Hi
    P0460 Fuel Level Unit No Change Over Miles
    P0461 Fuel Level Unit No Changeover Time
    P0462 Fuel Level Sending Unit Volts Too Low
    P0463 Fuel Level Sending Unit Volts Too Hi
    P0464 Fuel Level Sens A Circ Interm
    P0465 EVAP Purge Flow Sens Circ
    P0466 EVAP Purge Flow Sens Circ Range/Perf
    P0467 EVAP Purge Flow Sens Circ Low
    P0468 EVAP Purge Flow Sens Circ Hi
    P0469 EVAP Purge Flow Sens Circ Interm
    P0470 Exhaust Press Sens
    P0471 Exhaust Press Sens Range/Perf
    P0472 Exhaust Press Sens Low
    P0473 Exhaust Press Sens Hi
    P0474 Exhaust Press Sens Interm
    P0475 EPR Solenoid Circ
    P0476 Exhaust Press Ctrl Valve Range/Perf
    P0477 Exhaust Press Ctrl Relay Low
    P0478 Exhaust Press Ctrl Relay Hi
    P0479 Exhaust Press Ctrl Valve Interm
    P0480 Cooling Fan1 Ctrl Circ Open(Low speed fan)
    P0481 Fan 2 Ctrl Circ
    P0482 Fan 3 Ctrl Circ
    P0483 Cooling Fan Speed
    P0484 Fan Circ Over Current
    P0485 Fan Power/Ground Circ
    P0486 Exhaust Gas Recirculation Sens B Circ
    P0487 Exhaust Gas Recirculation Throttle Pos Ctrl Circ
    P0488 Exhaust Gas Recirculation Throttle Pos Ctrl Range/Perf
    P0489 Exhaust Gas Recirculation Ctrl Circ Low
    P0490 Exhaust Gas Recirculation Ctrl Circ Hi
    P0491 Sec Air Inj Sys Insufficient Flow Bank1
    P0492 Sec Air Inj Sys Insufficient Flow Bank2
    P0493 Fan Overspeed
    P0494 Fan Speed Low
    P0495 Fan Speed Hi
    P0496 EVAP Emission Sys Hi Purge Flow
    P0497 EVAP Emission Sys Low Purge Flow
  6. ramhunter9
    24,508
    885
    Jun 25, 2010
    Ram Year:
    Engine:
    P0500 - P0599
    P0500 No Vehicle Speed Sens Signal
    P0501 Vehicle Speed Sens Perf
    P0502 Vehicle Speed Sens A Circ Low Input
    P0503 Vehicle Speed Sens A Interm/Erratic/Hi
    P0504 Brake Switch A/B Correlation
    P0505 Idle Air Ctrl Motor Circs
    P0506 Idle Ctrl Sys Low RPM
    P0507 Idle Ctrl Sys Hi RPM
    P0508 Undercurrent condition detected in linear idle air Ctrl motor feedback sense Circ
    P0509 Over current condition detected in linear idle air Ctrl motor feedback sense Circ
    P0510 Closed Throttle Pos Switch
    P0511 Idle Air Ctrl Circ
    P0512 Starter Request Circ
    P0513 Incorrect Immobilizer Key
    P0514 Battery Temp Sens Perf
    P0515 Battery Temp Sens Circ
    P0516 Battery Temp Sens Low
    P0517 Battery Temp Sens Hi
    P0518 Idle Air Ctrl Circ Interm
    P0519 Idle Air Ctrl Sys Perf
    P0520 Engine Oil Press Sens/Switch Circ
    P0521 Oil Press Sens Perf
    P0522 Oil Press Sens Low
    P0523 Oil Press Sens Hi
    P0524 Oil Press Too Low
    P0525 Cruise Ctrl Servo Ctrl Circ Range/Perf
    P0526 Fan Speed Sens Circ
    P0527 Fan Speed Sens Circ Range/Perf
    P0528 Fan Speed Sens Circ No Signal
    P0529 Fan Speed Sens Circ Interm
    P0530 A/C Refrigerant Press Sens A Circ
    P0531 A/C Refrigerant Press Sens A Circ Range/Perf
    P0532 A/C Press Sens Low
    P0533 A/C Press Sens Hi
    P0534 Air Conditioner Refrigerant Charge Loss
    P0535 A/C Evaporator Temp Sens Circ
    P0536 A/C Evaporator Temp Sens Circ Range/Perf
    P0537 A/C Evaporator Temp Sens Circ Low
    P0538 A/C Evaporator Temp Sens Circ Hi
    P0539 A/C Evaporator Temp Sens Circ Interm
    P0540 Intake Air Heater A Circ
    P0541 Intake Air Relay 1 Low
    P0542 Intake Air Relay 1 Hi
    P0543 Intake Air Heater A Circ Open
    P0544 Exhaust Gas Temp Sens Circ Bank1 Sens1
    P0545 A/C Clutch Relay Circ
    P0546 Exhaust Gas Temp Sens Circ Hi Bank1 Sens1
    P0547 Exhaust Gas Temp Sens Circ Bank2 Sens1
    P0548 Exhaust Gas Temp Sens Circ Low Bank2 Sens1
    P0549 Exhaust Gas Temp Sens Circ Hi Bank2 Sens1
    P0550 Power Steering Press Sens/Switch Circ
    P0551 Power Steering Switch Failure
    P0552 Power Steering Press Sens/Switch Circ Low Input
    P0553 Power Steering Press Sens/Switch Circ Hi Input
    P0554 Power Steering Press Sens/Switch Circ Interm
    P0555 Brake Booster Press Sens Circ
    P0556 Brake Booster Press Sens Circ Range/Perf
    P0557 Brake Booster Press Sens Circ Low Input
    P0558 Brake Booster Press Sens Circ Hi Input
    P0559 Brake Booster Press Sens Circ Interm
    P0560 Sys Voltage
    P0561 Sys Voltage Unstable
    P0562 Charging Sys Voltage Too Low
    P0563 Charging Sys Voltage Too Hi
    P0564 Cruise Ctrl Multi-Function Input A Circ
    P0565 Cruise Ctrl On Signal
    P0566 Cruise Ctrl Off Signal
    P0567 Cruise Resume Circ
    P0568 Cruise Set Circ
    P0569 Cruise Ctrl Coast Signal
    P0570 Cruise Ctrl Accelerate Signal
    P0571 Cruise Brake Switch Circ
    P0572 Brake Switch 1 Low
    P0573 Brake Switch 1 Hi
    P0574 Cruise Ctrl Sys-Vehicle Speed Too Hi
    P0575 Cruise Switch Failure (Shorted)
    P0576 Cruise Ctrl Input Circ Low
    P0577 Cruise Switch Failure (Open)
    P0578 Cruise Ctrl Multi-Function Input A Circ Stuck
    P0579 Cruise Ctrl Multi-Function Input A Circ Range/Perf
    P0580 Speed Ctrl Multiplexed Switch 1 Low
    P0581 Speed Ctrl Multiplexed Switch 1 Hi
    P0582 Cruise Ctrl Vacuum Ctrl Circ/Open
    P0583 Cruise Ctrl Vacuum Ctrl Circ Low
    P0584 Cruise Ctrl Vacuum Ctrl Circ Hi
    P0585 Cruise Ctrl Multi-Function Input A/B Correlation
    P0586 Cruise Ctrl Vent Ctrl Circ/Open
    P0587 Cruise Ctrl Vent Ctrl Circ Low
    P0588 Cruise Ctrl Vent Ctrl Circ Hi
    P0589 Cruise Ctrl Multi-Function Input B Circ
    P0590 Cruise Ctrl Multi-Function Input B Circ Stuck
    P0591 Cruise Ctrl Multi-Function Input B Circ Range/Perf
    P0592 Cruise Ctrl Multi-Function Input B Circ Low
    P0593 Cruise Ctrl Multi-Function Input B Circ Hi
    P0594 Cruise Ctrl Servo Ctrl Circ/Open
    P0595 Cruise Ctrl Servo Ctrl Circ Low
    P0596 Cruise Ctrl Servo Ctrl Circ Hi
    P0597 Thermostat Heater Ctrl Circ/Open
    P0598 Thermostat Heater Ctrl Circ Low
    P0599 Thermostat Heater Ctrl Circ Hi
  7. ramhunter9
    24,508
    885
    Jun 25, 2010
    Ram Year:
    Engine:
    P0600 - P0699
    P0600 PCM Failure SPI Comms
    P0601 PCM Internal Ctrller Failure
    P0602 ECM Fueling Calibration Error
    P0603 VCM Memory Reset
    P0604 RAM Check Failure
    P0605 ROM Check Failure
    P0606 ECM Failure
    P0607 ECU Internal Perf
    P0608 Ctrl Mod VSS Output A
    P0609 Ctrl Mod VSS Output B
    P0610 Ctrl Mod Vehicle Options Error
    P0611 Fuel Injector Ctrl Mod Perf
    P0612 Fuel Injector Ctrl Mod Relay Ctrl
    P0613 TCM Processor
    P0614 ECM / TCM Incompatible
    P0615 Starter Relay Ctrl Circ
    P0616 Starter Relay Circ Low
    P0617 Starter Relay Circ Hi
    P0618 Alternative Fuel Ctrl Mod KAM Error
    P0619 Alternative Fuel Ctrl Mod RAM/ROM Error
    P0620 Generator Ctrl Circ
    P0621 Alternator L Terminal Circ
    P0622 Alternator Field Not Switching Properly
    P0623 Generator Lamp Ctrl Circ
    P0624 Fuel Cap Lamp Ctrl Circ
    P0625 Generator Field/F Terminal Circ Low
    P0626 Generator Field/F Terminal Circ Hi
    P0627 Fuel Pump A Ctrl Circ /Open
    P0628 Fuel Pump Relay Circ Low (or)
    P0628 Fuel Lift Pump Ctrl Circ Low
    P0629 Fuel Pump Relay Circ Hi (or)
    P0629 Fuel Lift Pump Ctrl Circ Hi
    P0630 VIN Not Programmed in PCM
    P0631 VIN Not Programmed or Incompatible-TCM
    P0632 Odometer Not Programmed-ECM/PCM
    P0633 SKIM Key Not Programmed in PCM
    P0634 PCM/ECM/TCM Internal Temp Too Hi
    P0635 Power Steering Ctrl Circ
    P0636 Power Steering Ctrl Circ Low
    P0637 Power Steering Ctrl Circ Hi
    P0638 Throttle Actuator Ctrl Range/Perf Bank1
    P0639 Throttle Actuator Ctrl Range/Perf Bank2
    P0640 Intake Air Heater Ctrl Circ
    P0641 Sens Ref Voltage A Circ/Open
    P0642 Sens Ref Voltage 1 Circ Low
    P0643 Sens Ref Voltage 1 Circ Hi
    P0644 Driver Display Serial Comm Circ
    P0645 A/C Clutch Relay Circ Perf
    P0646 A/C Clutch Relay Circ Low
    P0647 A/C Clutch Relay Circ Hi
    P0648 Immobilizer Lamp Ctrl Circ
    P0649 Speed Ctrl Lamp Ctrl Circ
    P0650 Malfunction Indicator Lamp (MIL) Circ
    P0651 Sens Ref Voltage B Circ/Open
    P0652 Sens Ref Voltage 2 Circ Low
    P0653 Sens Ref Voltage 2 Circ Hi
    P0654 Engine Speed Output Circ
    P0655 Engine Hot Lamp Output Ctrl Circ
    P0656 Fuel Level Output Circ
    P0657 Actuator Supply Voltage A Circ/Open
    P0658 Actuator Supply Voltage A Circ Low
    P0659 Actuator Supply Voltage A Circ Hi
    P0660 Intake Manif Tuning Valve Ctrl Circ/Open Bank1
    P0661 Intake Manif Tuning Valve Ctrl Circ Low Bank1
    P0662 Intake Manif Tuning Valve Ctrl Circ Hi Bank1
    P0663 Intake Manif Tuning Valve Ctrl Circ/Open Bank2
    P0664 Intake Manif Tuning Valve Ctrl Circ Low Bank2
    P0665 Intake Manif Tuning Valve Ctrl Circ Hi Bank2
    P0666 PCM/ECM/TCM Internal Temp Sens Circ
    P0667 PCM/ECM/TCM Internal Temp Sens Range/Perf
    P0668 PCM/ECM/TCM Internal Temp Sens Circ Low
    P0669 PCM/ECM/TCM Internal Temp Sens Circ Hi
    P0670 Glow Plug Mod Ctrl Circ
    P0671 Cylinder 1 Glow Plug Circ
    P0672 Cylinder 2 Glow Plug Circ
    P0673 Cylinder 3 Glow Plug Circ
    P0674 Cylinder 4 Glow Plug Circ
    P0675 Cylinder 5 Glow Plug Circ
    P0676 Cylinder 6 Glow Plug Circ
    P0677 Cylinder 7 Glow Plug Circ
    P0678 Cylinder 8 Glow Plug Circ
    P0679 Cylinder 9 Glow Plug Circ
    P0680 Cylinder 10 Glow Plug Circ
    P0681 Cylinder 11 Glow Plug Circ
    P0682 Cylinder 12 Glow Plug Circ
    P0683 Glow Plug Ctrl Mod to PCM Comm Circ
    P0684 Glow Plug Ctrl Mod to PCM Comm Circ Range/Perf
    P0685 ECM/PCM Power Relay Ctrl Circ /Open
    P0686 ECM/PCM Power Relay Ctrl Circ Low
    P0687 ECM/PCM Power Relay Ctrl Circ Hi
    P0688 ECM/PCM Power Relay Sense Circ /Open
    P0689 ECM/PCM Power Relay Sense Circ Low
    P0690 ECM/PCM Power Relay Sense Circ Hi
    P0691 Fan 1 Ctrl Circ Low
    P0692 Fan 1 Ctrl Circ Hi
    P0693 Fan 2 Ctrl Circ Low
    P0694 Fan 2 Ctrl Circ Hi
    P0695 Fan 3 Ctrl Circ Low
    P0696 Fan 3 Ctrl Circ Hi
    P0697 Sens Ref Voltage C Circ/Open
    P0698 Sens Ref Voltage 3 Circ Low
    P0699 Sens Ref Voltage 3 Circ Hi
  8. ramhunter9
    24,508
    885
    Jun 25, 2010
    Ram Year:
    Engine:
    P0700 - P0799
    P0700 EATX Ctrller DTC Present
    P0701 Trans Ctrl Sys Range/Perf
    P0702 Trans Ctrl Sys Electrical
    P0703 Brake Switch Sense Circ
    P0704 Clutch Switch Circ (M/T)
    P0705 Trans Range Sens Circ Malfunction (PRNDL Input)
    P0706 Trans Range Sens Circ Range/Perf
    P0707 Trans Range Sens Circ Low
    P0708 Trans Range Sens Circ Hi
    P0709 Trans Range Sens Circ Interm
    P0710 Trans Fluid Temp Sens A Circ
    P0711 Trans Temp Sens, No Temp Rise After Start
    P0712 Trans Temp Sens Voltage Too Low
    P0713 Trans Temp Sens Voltage Too Hi
    P0714 Trans Fluid Temp Sens A Circ Interm
    P0715 Input/Turbine Speed Sens A Circ
    P0716 Input/Turbine Speed Sens A Circ Range/Perf
    P0717 Input/Turbine Speed Sens A Circ No Signal
    P0718 Input/Turbine Speed Sens A Circ Interm
    P0719 Brake Switch B Circ Low
    P0720 Low Output SPEED Sens RPM, Above 15 MPH
    P0721 Output Speed Sens Circ Range/Perf
    P0722 Output Speed Sens Circ No Signal
    P0723 Output Speed Sens Circ Interm
    P0724 Brake Switch B Circ Hi
    P0725 Engine Speed Input Circ
    P0726 Engine Speed Input Circ Range/Perf
    P0727 Engine Speed Input Circ No Signal
    P0728 Engine Speed Input Circ Interm
    P0729 Gear 6 Incorrect Ratio
    P0730 Incorrect Gear Ratio
    P0731 Gear 1 Incorrect Ratio
    P0732 Gear 2 Incorrect Ratio
    P0733 Gear 3 Incorrect Ratio
    P0734 Gear 4 Incorrect Ratio
    P0735 Gear 5 Incorrect Ratio
    P0736 Reverse Incorrect Ratio
    P0737 TCM Engine Speed Output Circ
    P0738 TCM Engine Speed Output Circ Low
    P0739 TCM Engine Speed Output Circ Hi
    P0740 Torque Conv Clutch, No RPM Drop at Lockup
    P0741 Torque Conv Clutch Circ Perf or Stuck Off
    P0742 Torque Conv Clutch Circ Stuck On
    P0743 Torque Conv Clutch Solenoid/Trans Relay Circs
    P0744 Torque Conv Clutch Circ Interm
    P0745 Press Ctrl Solenoid A
    P0746 Press Ctrl Solenoid A Perf or Stuck Off
    P0747 Press Ctrl Solenoid A Stuck On
    P0748 Governor Press Sol Ctrl/Trans Relay Circs
    P0749 Press Ctrl Solenoid A Interm
    P0750 Shift Solenoid A
    P0751 O/D Switch Pressed (Low) More Than 5 Minutes
    P0752 Shift Solenoid A Stuck On
    P0753 Trans 3-4 Shift Sol/Trans Relay Circs
    P0754 Shift Solenoid A Interm
    P0755 Shift Solenoid B
    P0756 AW4 Shift Sol B (2-3) Functional Failure
    P0757 Shift Solenoid B Stuck On
    P0758 Shift Solenoid B Electrical
    P0759 Shift Solenoid B Interm
    P0760 Shift Solenoid C
    P0761 Shift Solenoid C Perf or Stuck Off
    P0762 Shift Solenoid C Stuck On
    P0763 Shift Solenoid C Electrical
    P0764 Shift Solenoid C Interm
    P0765 Shift Solenoid D
    P0766 Shift Solenoid D Perf or Stuck Off
    P0767 Shift Solenoid D Stuck On
    P0768 Shift Solenoid D Electrical
    P0769 Shift Solenoid D Interm
    P0770 Shift Solenoid E
    P0771 Shift Solenoid E Perf or Stuck Off
    P0772 Shift Solenoid E Stuck On
    P0773 Shift Solenoid E Electrical
    P0774 Shift Solenoid E Interm
    P0775 Press Ctrl Solenoid B
    P0776 Press Ctrl Solenoid B Perf or Stuck off
    P0777 Press Ctrl Solenoid B Stuck On
    P0778 Press Ctrl Solenoid B Electrical
    P0779 Press Ctrl Solenoid B Interm
    P0780 Shift Error
    P0781 1-2 Shift
    P0782 2-3 Shift
    P0783 3-4 Shift Sol, No RPM Drop at Lockup
    P0784 4-5 Shift
    P0785 Shift/Timing Solenoid
    P0786 Shift/Timing Solenoid Range/Perf
    P0787 Shift/Timing Solenoid Low
    P0788 Shift/Timing Solenoid Hi
    P0789 Shift/Timing Solenoid Interm
    P0790 Normal/Perf Switch Circ
    P0791 Intermediate Shaft Speed Sens A Circ
    P0792 Intermediate Shaft Speed Sens A Circ Range/Perf
    P0793 Intermediate Shaft Speed Sens A Circ No Signal
    P0794 Intermediate Shaft Speed Sens A Circ Interm
    P0795 Press Ctrl Solenoid C
    P0796 Press Ctrl Solenoid C Perf or Stuck off
    P0797 Press Ctrl Solenoid C Stuck On
    P0798 Press Ctrl Solenoid C Electrical
    P0799 Press Ctrl Solenoid C Interm
  9. ramhunter9
    24,508
    885
    Jun 25, 2010
    Ram Year:
    Engine:
    P0800 - P0899
    P0800 Transfer Case Ctrl Sys (MIL Request)
    P0801 Reverse Gear Lockout Circ Open or Short
    P0802 Trans Ctrl Sys MIL Request Circ/Open
    P0803 1-4 Upshift (Skip Shift) Solenoid Ctrl Circ
    P0804 1-4 Upshift (Skip Shift) Lamp Ctrl Circ
    P0805 Clutch Pos Sens Circ
    P0806 Clutch Pos Sens Circ Range/Perf
    P0807 Clutch Pos Sens Circ Low
    P0808 Clutch Pos Sens Circ Hi
    P0809 Clutch Pos Sens Circ Interm
    P0810 Clutch Pos Ctrl Error
    P0811 Excessive Clutch Slippage
    P0812 Reverse Input Circ
    P0813 Reverse Output Circ
    P0814 Trans Range Display Circ
    P0815 Upshift Switch Circ
    P0816 Downshift Switch Circ
    P0817 Starter Disable Circ
    P0818 Driveline Disconnect Switch Input Circ
    P0819 Up and Down Shift Switch to Trans Range Correlation
    P0820 Gear Lever X-Y Pos Sens Circ
    P0821 Gear Lever X Pos Circ
    P0822 Gear Lever Y Pos Circ
    P0823 Gear Lever X Pos Circ Interm
    P0824 Gear Lever Y Pos Circ Interm
    P0825 Gear Lever Push-Pull Switch (Shift Anticipate)
    P0826 Up and Down Shift Switch Circ
    P0827 Up and Down Shift Switch Circ Low
    P0828 Up and Down Shift Switch Circ Hi
    P0829 5-6 Shift
    P0830 Clutch Depressed Switch Circ
    P0831 Clutch Pedal Switch A Circ Low
    P0832 Clutch Pedal Switch A Circ Hi
    P0833 Clutch Released Switch Circ
    P0834 Clutch Pedal Switch B Circ Low
    P0835 Clutch Pedal Switch B Circ Hi
    P0836 Four Wheel Drive (4WD) Switch Circ
    P0837 4WD Switch Perf
    P0838 4WD Switch Circ Low
    P0839 4WD Switch Circ Hi
    P0840 Trans Fluid Press Sens/Switch A Circ
    P0841 Trans Fluid Press Sens/Switch A Circ Range/Perf
    P0842 Trans Fluid Press Sens/Switch A Circ Low
    P0843 Trans Fluid Press Sens/Switch A Circ Hi
    P0844 Trans Fluid Press Sens/Switch A Circ Interm
    P0845 Trans Fluid Press Sens/Switch B Circ
    P0846 Trans Fluid Press Sens/Switch B Circ Range/Perf
    P0847 Trans Fluid Press Sens/Switch B Circ Low
    P0848 Trans Fluid Press Sens/Switch B Circ Hi
    P0849 Trans Fluid Press Sens/Switch B Circ Interm
    P0850 Park/Neutral Switch Input Circ
    P0851 Park/Neutral Switch Input Circ Low
    P0852 Park/Neutral Switch Input Circ Hi
    P0853 Drive Switch Input Circ
    P0854 Drive Switch Input Circ Low
    P0855 Drive Switch Input Circ Hi
    P0856 Traction Ctrl Input Signal
    P0857 Traction Ctrl Input Signal Range/Perf
    P0858 Traction Ctrl Input Signal Low
    P0859 Traction Ctrl Input Signal Hi
    P0860 Gear Shift Mod Comm Circ
    P0861 Gear Shift Mod Comm Circ Low
    P0862 Gear Shift Mod Comm Circ Hi
    P0863 TCM Comm Circ
    P0864 TCM Comm Circ Range/Perf
    P0865 TCM Comm Circ Low
    P0866 TCM Comm Circ Hi
    P0867 Trans Fluid Press
    P0868 Trans Fluid Press Low
    P0869 Trans Fluid Press Hi
    P0870 Trans Fluid Press Sens/Switch C Circ
    P0871 Trans Fluid Press Sens/Switch C Circ Range/Perf
    P0872 Trans Fluid Press Sens/Switch C Circ Low
    P0873 Trans Fluid Press Sens/Switch C Circ Hi
    P0874 Trans Fluid Press Sens/Switch C Circ Interm
    P0875 Trans Fluid Press Sens/Switch D Circ
    P0876 Trans Fluid Press Sens/Switch D Circ Range/Perf
    P0877 Trans Fluid Press Sens/Switch D Circ Low
    P0878 Trans Fluid Press Sens/Switch D Circ Hi
    P0879 Trans Fluid Press Sens/Switch D Circ Interm
    P0880 TCM Power Input Signal
    P0881 TCM Power Input Signal Range/Perf
    P0882 TCM Power Input Signal Low
    P0883 TCM Power Input Signal Hi
    P0884 TCM Power Input Signal Interm
    P0885 TCM Power Relay Ctrl Circ/Open
    P0886 TCM Power Relay Ctrl Circ Low
    P0887 TCM Power Relay Ctrl Circ Hi
    P0888 TCM Power Relay Sense Circ
    P0889 TCM Power Relay Sense Circ Range/Perf
    P0890 TCM Power Relay Sense Circ Low
    P0891 TCM Power Relay Sense Circ Hi
    P0892 TCM Power Relay Sense Circ Interm
    P0893 Multiple Gears Engaged
    P0894 Trans Component Slipping
    P0895 Shift Time Too Short
    P0896 Shift Time Too Long
    P0897 Trans Fluid Deteriorated
    P0898 Trans Ctrl Sys MIL Request Circ Low
  10. ramhunter9
    24,508
    885
    Jun 25, 2010
    Ram Year:
    Engine:
    P0900 - P0999
    P0900 Clutch Actuator Circ/Open
    P0901 Clutch Actuator Circ Range/Perf
    P0902 Clutch Actuator Circ Low
    P0903 Clutch Actuator Circ Hi
    P0904 Gate Select Pos Circ
    P0905 Gate Select Pos Circ Range/Perf
    P0906 Gate Select Pos Circ Low
    P0907 Gate Select Pos Circ Hi
    P0908 Gate Select Pos Circ Interm
    P0909 Gate Select Ctrl Error
    P0910 Gate Select Actuator Circ/Open
    P0911 Gate Select Actuator Circ Range/Perf
    P0912 Gate Select Actuator Circ Low
    P0913 Gate Select Actuator Circ Hi
    P0914 Gear Shift Pos Circ
    P0915 Gear Shift Pos Circ Range/Perf
    P0916 Gear Shift Pos Circ Low
    P0917 Gear Shift Pos Circ Hi
    P0918 Gear Shift Pos Circ Interm
    P0919 Gear Shift Pos Ctrl Error
    P0920 Gear Shift Forward Actuator Circ/Open
    P0921 Gear Shift Forward Actuator Circ Range/Perf
    P0922 Gear Shift Forward Actuator Circ Low
    P0923 Gear Shift Forward Actuator Circ Hi
    P0924 Gear Shift Reverse Actuator Circ/Open
    P0925 Gear Shift Reverse Actuator Circ Range/Perf
    P0926 Gear Shift Reverse Actuator Circ Low
    P0927 Gear Shift Reverse Actuator Circ Hi
    P0928 Gear Shift Lock Solenoid Ctrl Circ/Open
    P0929 Gear Shift Lock Solenoid Ctrl Circ Range/Perf
    P0930 Gear Shift Lock Solenoid Ctrl Circ Low
    P0931 Gear Shift Lock Solenoid Ctrl Circ Hi
    P0932 Hydraulic Press Sens Circ
    P0933 Hydraulic Press Sens Range/Perf
    P0934 Hydraulic Press Sens Circ Low
    P0935 Hydraulic Press Sens Circ Hi
    P0936 Hydraulic Press Sens Circ Interm
    P0937 Hydraulic Oil Temp Sens Circ
    P0938 Hydraulic Oil Temp Sens Range/Perf
    P0939 Hydraulic Oil Temp Sens Circ Low
    P0940 Hydraulic Oil Temp Sens Circ Hi
    P0941 Hydraulic Oil Temp Sens Circ Interm
    P0942 Hydraulic Press Unit
    P0943 Hydraulic Press Unit Cycling Period Too Short
    P0944 Hydraulic Press Unit Loss of Press
    P0945 Hydraulic Pump Relay Circ/Open
    P0946 Hydraulic Pump Relay Circ Range/Perf
    P0947 Hydraulic Pump Relay Circ Low
    P0948 Hydraulic Pump Relay Circ Hi
    P0949 Auto Shift Manual Adaptive Learning Not Complete
    P0950 Auto Shift Manual Ctrl Circ
    P0951 Auto Shift Manual Ctrl Circ Range/Perf
    P0952 Auto Shift Manual Ctrl Circ Low
    P0953 Auto Shift Manual Ctrl Circ Hi
    P0954 Auto Shift Manual Ctrl Circ Interm
    P0955 Auto Shift Manual Mode Circ
    P0956 Auto Shift Manual Mode Circ Range/Perf
    P0957 Auto Shift Manual Mode Circ Low
    P0958 Auto Shift Manual Mode Circ Hi
    P0959 Auto Shift Manual Mode Circ Interm
    P0960 Press Ctrl Solenoid A Ctrl Circ/Open
    P0961 Press Ctrl Solenoid A Ctrl Circ Range/Perf
    P0962 Press Ctrl Solenoid A Ctrl Circ Low
    P0963 Press Ctrl Solenoid A Ctrl Circ Hi
    P0964 Press Ctrl Solenoid B Ctrl Circ/Open
    P0965 Press Ctrl Solenoid B Ctrl Circ Range/Perf
    P0966 Press Ctrl Solenoid B Ctrl Circ Low
    P0967 Press Ctrl Solenoid B Ctrl Circ Hi
    P0968 Press Ctrl Solenoid C Ctrl Circ/Open
    P0969 Press Ctrl Solenoid C Ctrl Circ Range/Perf
    P0970 Press Ctrl Solenoid C Ctrl Circ Low
    P0971 Press Ctrl Solenoid C Ctrl Circ Hi
    P0972 Shift Solenoid A Ctrl Circ Range/Perf
    P0973 Shift Solenoid A Ctrl Circ Low
    P0974 Shift Solenoid A Ctrl Circ Hi
    P0975 Shift Solenoid B Ctrl Circ Range/Perf
    P0976 Shift Solenoid B Ctrl Circ Low
    P0977 Shift Solenoid B Ctrl Circ Hi
    P0978 Shift Solenoid C Ctrl Circ Range/Perf
    P0979 Shift Solenoid C Ctrl Circ Low
    P0980 Shift Solenoid C Ctrl Circ Hi
    P0981 Shift Solenoid D Ctrl Circ Range/Perf
    P0982 Shift Solenoid D Ctrl Circ Low
    P0983 Shift Solenoid D Ctrl Circ Hi
    P0984 Shift Solenoid E Ctrl Circ Range/Perf
    P0985 Shift Solenoid E Ctrl Circ Low
    P0986 Shift Solenoid E Ctrl Circ Hi
    P0987 Trans Fluid Press Sens/Switch E Circ
    P0988 Trans Fluid Press Sens/Switch E Circ Range/Perf
    P0989 Trans Fluid Press Sens/Switch E Circ Low
    P0990 Trans Fluid Press Sens/Switch E Circ Hi
    P0991 Trans Fluid Press Sens/Switch E Circ Interm
    P0992 Trans Fluid Press Sens/Switch F Circ
    P0993 Trans Fluid Press Sens/Switch F Circ Range/Perf
    P0994 Trans Fluid Press Sens/Switch F Circ Low
    P0995 Trans Fluid Press Sens/Switch F Circ Hi
    P0996 Trans Fluid Press Sens/Switch F Circ Interm
    P0997 Shift Solenoid F Ctrl Circ Range/Perf
    P0998 Shift Solenoid F Ctrl Circ Low
    P0999 Shift Solenoid F Ctrl Circ Hi
Thread Status:
Share This Page
