FF/EMT Brzak
- Mar 11, 2017
- 7
- 4
- 2009
- Hemi 5.7
Ive had a great deal of stress with this truck. 2009 Dodge Ram 1500 that had the rear end seize up from a recall that was performed, and still failed, which dropped the driveshaft in the process, and then cracked my transmission motor, and transfer case from the force of the driveshaft spinning at 60mph. After that, I lost compression in cylinder 6, having the whole top half of the motor rebuilt, and now itwon’t run. I turn the key over, and it turns over all day long, but will not run. I’ve replaced camshaft sensor, and crankshaft sensor in hopes from other forums were right, but weren’t. The TIPM is good as well as the fuel pump. I can hear the pump, and you can smell the gas when it turns over. Weird thing, I unplugged the camshaft sensor, and it runs for a few seconds at a time with it unplugged. I did a diagnosis with a Mac tools scanner, and it brought up a code for the ASD. I checked all wires going to the TIPM, fuses involving the ASD, and everything seems fine. I’m just really not wanting to take this to the stealership if I don’t have to. Anything at this point would be appreciated. Sorry if somebody else posted this same problem, I just didn’t find anything while searching
