Truck skipping/jerking?
Discussion in 'Engine & Performance' started by Coletrain523, Dec 18, 2016.
Sponsored By: Moe's Performance
  1. Coletrain523
    Coletrain523 Member
    36
    Nov 6, 2014
    Ram Year:
    2001
    Engine:
    magnum 5.9
    So I've noticed within the past few days that when I'm driving down the road the truck at random times will jerk, not like a shake but just a sudden jolt and idk why it started doing this. The truck starts fine no matter how cold or hot. And it only does it at random times, yesterday it did it almost all day. But today it hasn't done it at all. I wouldn't say it has a rough idle, but it kinda Jerks a little. Not very noticeable. And I'm not sure what to do any help is greatly appreciated. 2001 dodge ram 1500 4x4 5.9
  2. MADDOG
    MADDOG Super Moderator Staff Member
    7,130
    1,880
    Dec 26, 2011
    Oregon
    Ram Year:
    Engine:
    Cummins 6.7L Turbo Diesel
    It could be electrical or fuel such a bad injector, fuel pump, fuel system freezing, a failing plug or plug wire that has a small short, etc....
    Are you getting any flicker in the dash lights? Is your check engine light on?
  3. Coletrain523
    Coletrain523 Member
    36
    Nov 6, 2014
    Ram Year:
    2001
    Engine:
    magnum 5.9
    No flickering. And no check engine light.
  4. aheeejd
    aheeejd Senior Member
    114
    35
    Aug 30, 2014
    Ram Year:
    2003
    Engine:
    4.7 V8
    I experienced what you're talking about I think & always a few days or weeks of it starting I always got a whatever # cylinder misfire. Plugs/colipacks. Mine is 4.7 though
    Sent from my LG-ls990 using Tapatalk
  5. Coletrain523
    Coletrain523 Member
    36
    Nov 6, 2014
    Ram Year:
    2001
    Engine:
    magnum 5.9
    So the truck is jerking a lot more. Enough to that I've stopped driving it for fear of it breaking bad. I checked the spark plugs to see if they were corroded or anything like that and the wires seem fine and the plugs have a very small coat of white powder on the tips. But seem to have oil on the threads and back end of the plug?
  6. Yeret
    Yeret Senior Member
    28
    706
    115
    Oct 2, 2014
    Under the hood, trying to find that ****ing bolt/n
    Ram Year:
    1999
    Engine:
    5.9 Magnum
    How's your oil consumption? If excessive, has the plenum repair been done?
  7. Coletrain523
    Coletrain523 Member
    36
    Nov 6, 2014
    Ram Year:
    2001
    Engine:
    magnum 5.9
    It does use oil. I change my oil every 3000 miles, and I probably have to put about 2 courts, maybe just 1 in before I have to change it. I am the second owner and I've never changed it. And I don't believe the previous owner had either.
  8. Coletrain523
    Coletrain523 Member
    36
    Nov 6, 2014
    Ram Year:
    2001
    Engine:
    magnum 5.9
    I have noticed that every time I drive the truck and then get out all you can smell is burning oil. But the truck run fine until now?
  9. Yeret
    Yeret Senior Member
    28
    706
    115
    Oct 2, 2014
    Ram Year:
    1999
    Engine:
    5.9 Magnum
    Could be a heavy leak from the valve covers. Oil might be finding it's way into the spark plug chambers which would explain the oil on the plugs and on the manifolds which would explain the burning smell. If oil manages to reach the terminal of the plug (which I have actually seen before), it could short it out or weaken the spark.
    Can you confirm a leak from the valve covers?
  10. Coletrain523
    Coletrain523 Member
    36
    Nov 6, 2014
    Ram Year:
    2001
    Engine:
    magnum 5.9
    So I've took the truck to a new shop (I don't have a mechanic) and they apparently did a test for the plenum gasket and said it was good (didn't think there was a test for that so idk what to think about that) but they did say the valve cover gasket was bad. And that they are going to change the plugs, wires, rotor, and valve cover gasket. Does that sound like a good solution for the problem or are they screwing with me?
Share This Page
