Tuftruck HD Springs
Discussion in 'Towing & Hauling' started by nbonci, Aug 9, 2015.
  1. PippinAin'tEasy
    PippinAin'tEasy Senior Member
    699
    335
    Aug 8, 2014
    Ram Year:
    Engine:
    Keep closer to level @ 5psi since you already dropped the coin on yer 2.75's. Depends on how often you haul and yer budget, I reckon.
    Sent from my SAMSUNG-SGH-I547 using Tapatalk
  2. nbonci
    nbonci Junior Member
    29
    21
    Sep 30, 2014
    Kansas City, KS
    Ram Year:
    Engine:
    HEMI 5.7
    I end up hauling more than the motorcycle a couple time a month. It's not uncommon for me to haul lumber, and other building materials during my side jobs. I'd say that the springs are within my budget, most important would be doing the job right and something that will last. Not necessarily what's cheapest.
  3. BoldAdventure
    BoldAdventure Senior Member
    1,307
    748
    Jun 21, 2014
    Airstream, USA
    Ram Year:
    Engine:
    Get the springs and be done with it. Putting a cycle in the back and towing, you don't want to deal with bags. I ditched the bags and have the 50%.
    [​IMG]
    Today - and I have 2.8 blistens up front.
    [​IMG]
  4. nbonci
    29
    21
    Sep 30, 2014
    Kansas City, KS
    Ram Year:
    Engine:
    HEMI 5.7
    looks good, would you recommend swapping out shocks with the 50%? How much did they lift your back end? How is the ride without a load?
  5. BoldAdventure
    1,307
    748
    Jun 21, 2014
    Airstream, USA
    Ram Year:
    Engine:
    I have 50% because I'm always loaded. Either with trailer tongue weight or the generator + gas + water + 2 kids & wife. I swapped shocks at all 4 corners. And the ride isn't much different over stock. A little harsher over potholes or speed bumps.
    The 25% variables might work better for you. Bags are a hassle in my opinion, they keep the coil from compressing and make the ride harsh under load. This was my experience.
    How it rides is subjective. What might be harsh to you might be fine to me.
    I only experienced 2 inches in the back.
  6. nbonci
    29
    21
    Sep 30, 2014
    Kansas City, KS
    Ram Year:
    Engine:
    HEMI 5.7
    I just found part# TTC-1211 that will give that 50% increase in capacity while keeping the rear as close to stock as possible. Any thoughts on these? I know I am a little behind the curve as far as this stuff lol.
  7. cableguy_hd
    cableguy_hd Senior Member
    45
    1,472
    351
    May 2, 2013
    Danville, Va.
    Ram Year:
    2012 Ram Express
    Engine:
    That's what I have. raised the rear about 1/2"
  8. nbonci
    29
    21
    Sep 30, 2014
    Kansas City, KS
    Ram Year:
    Engine:
    HEMI 5.7
    Who did you order them from? I cannot seem to find them anywhere but the tough truck website.
  9. cableguy_hd
    45
    1,472
    351
    May 2, 2013
    Danville, Va.
    Ram Year:
    2012 Ram Express
    Engine:
    I got them from tuf truck. I called them and got them.
  10. audio1der
    audio1der Senior Member
    5,300
    1,081
    Jul 30, 2012
    Airdrie, Alberta
    Ram Year:
    Engine:
    If your truck is a daily driver, changing the springs to anything but the variable rate TTC will affect your ride quality.
    For a DD, airbags are honestly the best choice to keep the ride and reduce sag, for under $100 and an easy installation.
    I had Timbrens. For our application they replace the factory bumpstops. If you hit (engage) them, they are VERY hard, and it can cause jounce. We rode on ours fully engaged while towing and the ride was BRUTAL. I took them off after that 1 trip.
    If you do anything else with the truck, the springs might be a good choice; it's up to you and how you use the truck.
Share This Page
