- Nov 13, 2012
- 4,625
- 1,446
- Location
- Springfield, VA
- 2020
- 5.7L
Of course!Casper, you know I'm just mess'n with ya'
Wouldn't be any fun 'round here if everyone just pontificated all the time !
IDK about that, but yours clearly needs a pump and dump....!Maybe you need another catch can?
So, if running with a catch can, can one run at 87 instead of the recommended 89 since what the 89 is burning off will just be grabbed anyway.Haters gonna hate, and there are those on this forum who for some unknown reason insist on ridiculing catch cans. Whether through ignorance, delusion, denial or laziness, I can't determine and its probably different for every snark.
Facts:
1) The Hemi's higher compression, reduced number of piston rings, and short piston skirts produce a lot of blow by gases that wind up in the crankcase.
2) The Positive Crankcase Ventilation (PCV) on the Hemi uses vacuum from the intake manifold to remove oil vapor, combustion gases, combustion byproducts (varnish, carbon, unburned gasoline), water vapor and other volatized gases from the crankcase.
3) The same vacuum from the intake manifold that sucks the crud out of the Hemi crankcase via the PCV deposits it in the intake manifold as it is sucked through your valves and into your combustion chambers. In combustion chambers that crud interacts with your fuel air mixture in a deleterious (big word ) fashion.
4) The crud removed by your PCV is not good motor fuel (except maybe for a 2 cycle engine).
5) When motor oil mixed with water is exposed to the type of temperatures found in the combustion chamber it tends to leave additional nasty by-products behind.
Question: So do you really want to allow the items listed above to happen to your engine?
Remember: Chrysler doesn't care, they've passed the cost on to you via either having to use 89 Octane to burn that extra crud without your PCM pulling timing, or in increased/accelerated engine fouling to be discovered AFTER THE WARRANTY EXPIRES.
Or your favorite: a Chit-can!Maybe you need another catch can?
I do, with no obvious reduction in drive-ability.So, if running with a catch can, can one run at 87 instead of the recommended 89 since what the 89 is burning off will just be grabbed anyway.
Sent from my SM-G920V using Tapatalk
I have a Billet Technology catch can and it does not have the drain valve on it. I had one on the Challenger also, and after seeing the oil mist that would go back in the intake manifold, it sure will gum it up.
And with all of the sludge and oil I get in the winter months, there is no way it would drain out of a small valve. I only empty mine every 3K miles before I take it in for a oil change. It takes less than a minute to unscrew it, dump it out, and screw it back on.
Billet Technology Signature Series Catch Can For Dodge RAM 5.7L
https://www.redline-motorworks.com/...n-oil-catch-can-work-and-why-is-it-beneficial
Empty them when they're warm,i've ran Moroso catch cans on my last 2 Rams and on the wifes new Challenger,never had an issue draining them in the winter ,just drain them when the can is warm.No different then draining the oil in the winter.You don't try to change oil on a cold engine at -20,you warm it up first then drain the oil,do the same with a catch can,kind of a no brainer if you ask me,lol
You don't have any issues with them in cold weather? I have read many times that they freeze up and cause issues in cold climates.
How? they're attached to the engine block. 5 minutes after start up they're as warm as anything under the hood.You don't have any issues with them in cold weather? I have read many times that they freeze up and cause issues in cold climates.
