Uconnect upgrade
Smoltz
Georgia
After doing some research, i was trying to see if pulling a 2018 ram 1500 8.4 uconnect radio and putting it in my 2017 ram is a simple plug and play. I am trying to get carplay and trying to find the easiest way to do so and wanting to keep everything looking OEM. I know ill also have the get a new media hub as well.
PA Ram
Quakertown, PA
If you already have an 8.4 radio it is plug and play. Just have to make sure it's the Panasonic UAQ or UAS radio and not a Harmon Kardon. Only thing you should have to upgrade is the USB hub. The 2017 and older don't work with Android Auto. If you don't have the 8.4 radio you'll have to change your bezel to one for 8.4 radio.
Administrator
^^^ what he said, you'll need a new USB hub and wiring adapter harness.
You can find the harness here: https://www.m2mods4ram.com/4th-gen-ram-radio-upgrade
I have a UAQ in my '15. I also use an AAWireless module for wireless AndroidAuto, it supports wireless CarPlay now too.
S
Smoltz
Georgia
Awesome thanks guys! I have the 8.4in screen already. Is there a way to tell which radio I have instead of taking out the radio? Sorry for all the questions
Administrator
The pre-18 trucks had one of two 8.4 radios, the 8.4AN (RA4) had built in navigation and HD radio, and the 8.4A (RA3) which had neither but you could enable nav with a code.
Doesn't matter which one is in your truck now as either the UAS or UAQ will work. UAQ has built in navigation but your better off using AndroidAuto/CarPlay.
If you know the vehicle VIN which the radio is in(or pulled from) you can look up the build sheet:
(use all capital letters)
PA Ram
Quakertown, PA
What ^^^^^^ he said
WWlorodd1
Fort Worth, TX
2011 Ram Sport
I have a 2011 1500 with the uconnect 430 radio. If I by a used 430N for the navigation will it be plug and play?
jawzs2
South Jersey
Yes - it's pretty much a straight swap. The only issue you "might" run into is with the roof, (puck) antenna. The 430N uses one antenna for both Sirius and GPS. I had to change mine on my 2010. If I remember correctly, your 2011 should have the later model that does both, but it's been so long ago I can't be positive.
