Upper ball joint
pil03001
HEMI
I have a 09 with 130k on the clock and its time to replace the ball joints, since they have quite a bit of play in them. I started pressing the top one out and realized halfway through it may not push out correctly (appears to have a metal ring on both sides of the UCA. Has anyone replaced these before? Or has everyone gone the route of replacing the whole arm? (mevotech)
fordtech90
Jonesboro, La 71251
Upper ball joints are made with UCA. They are not a stand alone serviceable part. You must buy UCA to replace them. Mevotech are very good
P
pil03001
HEMI
If they are not serviceable then why do manufacturers sells stand alone ball joints?
Csanders1992
Some arms can be serviced, some it's stupid to. Mevotechs are cheap enough that you might as well just change the whole thing, then you'd have new uca bushings as well.
P
pil03001
HEMI
Fair enough, but I already have the upper and lower ball joint parts and was hoping someone had some tips and tricks to removing them. It would just suck waiting longer for parts and have the hassle of returning the others...
Joey93
