Mekcanix
- Jun 5, 2020
- 7
- 4
- Location
- Winnipeg, Manitoba Canada
- 2016
- 5.7
Good day,
I have a question for the masses. I have a 2016 ram rebel air deleted. I have added a 3" RC lift strut up front and the 2-3inch upper control arms, tubular. I have had them in for about 2 years. I have a winch behind the bumper and a setina (aluminum) push bar. So I net about 2 -1/4 lift/level.
I recently replaced the lower ball joints and in the process discovered the passenger one is loose. Turns out they are a special order from rough country which is a pain in the but in canada, or at least winnipeg. Budget is kinda tight. I can get the ball joints about 3 weeks 120$ each. So install myself no alignment required but if they fail I am back to special order parts. The other option is to install mevotech TTX arms and joints. I have read that they are ok for levelled trucks, but that means a alignment after the install.
Unfortunately the higher end arms are out of my budget for a bit of time. I tow a camper for most of the summer its around 5000 lbs.
I have been searching for info on these ball joints since the weekend and have found nothing on whats been sold to the ram guys. Also I think RC has possibly discontinued these arms.
So the question is: Which way would you go?
