Proby34
Need some urgent advice please! So, I had the dreaded cam issue and replaced my cam with a Comp Cam No Tune Required one with the MDS Delete. When I first swapped it out I messed up the timing so I pulled it off on my days off and corrected the timing as well as replaced the oil pump with the hellcat pump. I also replaced the VVT Solenoid, cam sensor, crank sensor is fairly new as well. I had the MDS Switch off on my tuner and everything is fine. I drove it all day yesterday and it was good, a little more back pressure than i would have liked, but otherwise good. Now today I went to leave for work and my truck immediately went into limp mode. I dont know if the cam relearn needs done again because I had it done the first time when the timing was off but they said they got it after a few attempts. I dont know what else to check. Could the harmonic balancer be bad and causing this? Totally lost so please help me!!
The only code im getting is the P0344 code with two others that correlate with it.
