Using Air Suspension Tank for filling RV tires
Ben W
Eau Claire
Diesel
Hello All, crawling under my 2020 Ram 3500 with air suspension i noticed an unused extra quick attach plug on the side of my OEM factory air tank.... and wondered if i could potentially install a line there and run it to my back bumper to occasionally use the tank to fill RV tires. Anyone know if this is a ridiculous idea? I’m picturing the air bags getting blasted unless I could put in a bypass valve somehow? What is the psi in that tank? is there a way to put an auxiliary switch in to control output for inflating tires?
Or is it just more practical to put in a second VIAir tank and control.
Thanks for the feedback.
Administrator
The system is charged with nitrogen like the 1500s. The compressor just reuses the nitrogen to inflate the rear bags from the holding tank.
Klienn makes a complete bolt air compressor w/tank kit for Ram trucks: https://kleinn.com/ram-systems/
Randy Grant
Ellensburg, WA 98926
Is your 3500 diesel? If it is and you have an exhaust brake(I think all do), then there should be a compressor and air tank. Tap off that tank/system. I haven't paid attention to the way the newer truck exhaust brake systems work, so just posing the question. Had an exhaust brake installed on my '05 Duramax, and had a quick connect in line at the compressor. Not good to air up a really low tire, but good for a top-off. Llso plumbed it into my rear air bags.
Sirry, but just checked how the newer brakes work, and they use the turbo as a variable brake/turbo. better off to get a dedicated system.
BWL
Embrace the skeptisism
BC Canada
Short answer is no. Even if it did it would be too low a volume compressor to be worth the effort. Just grab a 12v cig lighter one or a cordless one to keep stashed somewhere like in the rv for when you may need it.
