Vacuum Leak Help Needed (hissing)
JohnRBurke2
Detroit, mi.
5.2 V8 Magnum
2001 Dodge Ram 1500
5.2L V8
Vacuum Leak (I assume)
I am not an expert but I am hearing a hissing sound come and go when I start my truck from under my hood.
When the hissing starts, the truck sputters slightly and the rpm's drop slightly
when the hissing stops, the rpm's increase a little (then return to normal)
This process repeats when I start the truck and let it sit.
Any advise on how to find this (assumed) vacuum lead and fix it would be great!
Here is a link to a youtube video I uploaded showing this problem in action: Help Needed: 2001 Dodge Ram 1500 5.2 Vacuum Leak - YouTube
B-Shot
Have you check your pvc valve lately? my guess is the break booster check valve.
JohnRBurke2
JohnRBurke2
Detroit, mi.
5.2 V8 Magnum
Thanks! I will check it out today. Any advise on where to find this (I am sure I can youtube or Google it but maybe you can tell me before hand)
JohnRBurke2
JohnRBurke2
Detroit, mi.
5.2 V8 Magnum
I fixed the vacuum leak. It was the small hose the connects to the IAC and the air cleaner mounting gasket was missing between the air cleaner and the throttle body.
I appreciate the responses.
Ftank
