Vararam installed and not Happy!
I8U4DNR
Apache Juction AZ.
I installed the Vararam on my 2012 Ram but i am not Happy. After 2 times of opening the Hood i can see that there is a gap on the left side between the air filter and the plastic molding where dust and dirt can get into my engine. I have recently removed this System and will Be contacting Maryland Speed where i purchased it.
on another note it will do what it says. power increase that can feel and if you stay off the skinny pedal better gas milage will be seen. :wtf2:
holdstill79
There is a youtube video on how to "better seat" the filter into the housing.Try that first
Mopar_Express
Albany, NY
5.7L
Yea its a sumbitch but you have to really work the **** out of it to get it seated and tighten it wayyy down and keep your eye on it as the wing nuts tend to back off a little over time.
cbo
In it for the vid as well!
Designflaw
Lex. Ky.
2013 CC Sport 4x4
I'm getting ready to clean mine for the first time. I think it is going to suck trying to do it with the base installed on the truck, but then again, I think it sucks having to remove the base to install the filter properly! :emotions122:
There is no way you can put that much pressure on the top to get the back wing nut on, and not be pushing on the red boot to the Throttle body - OH now way the wing nuts level with the posts works either, they are spinny loose at that point for me
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
Yes, the Vararam kits use washable oiled filters.
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
Gotta Say it Looks Mean!
J-Dub
Hilltop Lakes, TX
I'm sure the performance is there and it does look good but I'm glad i have a system that is easier to mess with than having to seat a filter each time i clean it and having to worry about wing nuts backing off and stuff.
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
I think I have swapped so many of these lids that it is just second nature to me. Easiest way to do this is to just snug the wingnuts down a bit, then massage the filter into place, then tighten the nuts down so that about 3/4-1" of thread is showing.
I am also doing this on the ground though and not in the engine bay. It takes less time to remove the whole unit than it does to just remove the filter, so it may be worth the extra 2 minutes to remove the filter on the ground.
Goodie1990
