Vibration/Shudder Issue
Discussion in 'Tech Info' started by racepaul, Nov 15, 2016.
  1. racepaul
    racepaul Junior Member
    Nov 15, 2016
    Ram Year:
    2002
    Engine:
    5.9
    Hey All
    New to the forum and have a issue with my Dodge.
    2002 Dodge Ram 1500 2WD Quad cab ,long bed with a 5.9L
    My truck has a vibration at 30- 35 mph. This happens on acceleration, deceleration, in neutral and coasting with the engine off. I have had new tires installed and rebalanced, rotated the tires and the same issue.
    Checked all the front end while it was on the lift and it all looks good.
    Any thoughts?
  2. BrianandChrissy
    BrianandChrissy Senior Member
    48
    577
    210
    Jul 11, 2016
    Buffalo NY
    Ram Year:
    2016 big horn crew cab
    Engine:
    5.7 hemi, vararam CAI
    U-joints?
    sent from galaxy S7 edge using tapatalk
  3. BrianandChrissy
    48
    577
    210
    Jul 11, 2016
    Buffalo NY
    Ram Year:
    Engine:
    8' bed? Do you have a 2 piece driveshaft?
    Rustycowl69 likes this.
  4. racepaul
    Nov 15, 2016
    Ram Year:
    2002
    Engine:
    5.9
    U-joints seem good.
    Yes, two piece drive shaft.
    If makes any difference at all, those all seem to start after I had the brakes done.
  5. BrianandChrissy
    48
    577
    210
    Jul 11, 2016
    Buffalo NY
    Ram Year:
    Engine:
    There is a saddle between the 2 driveshafts. Check there. Could be worn out. Happened to my friends 3/4 ton chevy long bed.
  6. racepaul
    Nov 15, 2016
    Ram Year:
    2002
    Engine:
    5.9
    Driveshaft and u-joint all check out good.
    Any other suggestions?
  7. BrianandChrissy
    48
    577
    210
    Jul 11, 2016
    Buffalo NY
    Ram Year:
    Engine:
    Did you put new rotors on with the brake job?
  8. BrianandChrissy
    48
    577
    210
    Jul 11, 2016
    Buffalo NY
    Ram Year:
    Engine:
    Rotors may be warped
  9. racepaul
    Nov 15, 2016
    Ram Year:
    2002
    Engine:
    5.9
    I had the rotors turned and they are still within specs, also no vibration under braking.
  10. BrianandChrissy
    48
    577
    210
    Jul 11, 2016
    Buffalo NY
    Ram Year:
    Engine:
    Got me stumped
Share This Page
