- Apr 28, 2012
- 23,298
- 45,058
- 2010 Hemi Reg Cab 4x4
- Hemi
So I was a detailer back in the day, could kind of care less these days, I hardly wash my truck. But I thought I'd have some fun with it. I laughed when I recently seen a sealant test of ten products, and I had heard of none of them, seriously not one. So clearly, times have changed, but back in my day these two products were everyone's go to products for durability. So that is what I am testing, and I'll toss in a review maybe at the end. Now, I had only used double coat once before and gave up on it, but because of Pullya's suggestion I gave it another go. Prior Collonite white wax marque had been my go to wax for a decade. I'm running a separate test on the roof between all three Collinite's waxes-845, marque-double coat. It was that test that made me decide on DC for this test. As for the sealant, the best I know from my day z5pro, I choose not to use zfx this time or anything under each product.
Process, dawn wash until there was no sign of old sealant on the hood, tape down the middle. Apply double coat and z5pro by hand and remove by hand. Tomorrow, I will go back and repeat. That is it, that is all, I generally don't wash this truck, I will report anything if I see the hood stop beading, on one side or both whatever. It also sits outside.
Some pics...
wash.
Products
Collinite Finish
Z5Pro Finish
Beading After, yes I just did toss water on my wax test.
So thoughts, my camera's focus couldn't read the bottle on the wax side unless I laid the bottle right next to the hood, but it could read the zaino side a couple feet above the hood. That is what you call a mirror shine. Usually when you have a mirror shine you pay for it with a lack of wet look, but that is the one feature about z5pro that is different as it looks just as wet. Usually the muted effect of wax gives a wet look, and I can say from a looks standpoint I much prefer collonite marque to this double coat. But, this is really secondary to my main concern which is durability, we will likely not know the answer to this for months. I scrapped my other test, except I am also testing the 3 Collonites to see how they do against each other.
applied all 3 with space inbetween, there is a all in one paint cleaner as a base. Then it rained next day, you can see the large drops in the middle, and the reason I decided to go with double coat was because of info Pullya gave me and the Collonite website and these results, the last pic you can see how tiny the beads where in comparison to anything else double coat was the small beads, again you can see how big the beads are inbetween the waxes. So that's it, we are testing the three Collonites against each other, what I believe their most durable wax is against Zaino z5pro.
Time will tell, can a wax beat a sealant??
845 versus marque note large beads in middle
Marque versus Double Coat, Note the larger beads in the middle.
Some pics...
wash.
Products
Collinite Finish
Z5Pro Finish
