Weird smell coming from vents ...
Omegasupreme
Home
Changed cabin filter, did nothing. Smells like BO and burning rubber. Any ideas? It's unbearable. Only have 36,000 miles.
U&A
2016 3500 SRW
6.4 HEMI
Dose your truck make a loud squealing sounds and you see white smoke in your mirrors frequently?
Do you have a hemi?
Sent while firmly grasping my redline lubed RAM [emoji231]
O
Omegasupreme
Home
Do you have a hemi?
Unfortunately I do have the hemi. Bvery underpowered for how big it is. Ecoboost would be much better.
U&A
2016 3500 SRW
6.4 HEMI
Underpowered?
Compare it to the other V-8‘s in its class and then tell me if it’s under powered.
Eco-boost is TwinTurbo you can’t compare the two.
O
Omegasupreme
Home
Underpowered?
Compare to who? Ford? Chevy? All have more. Fca is just putting lipstick on an old pig.
madtrucker2016
New York
Their is a old trick at the dealer if they don't like you or your a problem customer they pour ***** in the vents across the top of the dashboard. That smell never goes away you would have to take the dash out and change out the vents:banana-mario:
SouthTexan
408 CTD
OP, You likely need to clean your heater coil or evaporator coil which is not easy to do.
I agree with you about the Ecoboost. I drove a 2012 that put down 420 hp and 510 lb-ft at the wheels with just a tune before I got my Ram and it would run like a scalded ape even with a trailer behind. Even in stock for it was pretty powerful especially in the lower rpms between 1,500 and 3,500 rpm. It also helped that it had way better trans gearing than the 66RFE hooked up to the 6.4L.
U&A
2016 3500 SRW
6.4 HEMI
Chevy 5.3 is 355/383
Ford5.0 is 395/400
Ram 5.7 is 395/410
Old pig or not. It is no slouch. And neither V8 has more than the ram.
Ribtipram
Braidwood il
My buddies new tahoe has more horse and tq then my 2500. Has the 6.2. I do like my truck though.
