What I learned replacing my speakers
Miami Son
Banned
Port St. Lucie, FL
2012 Ram 1500 Sport Crew Cab
Just tore open my truck to put in a set of Kicker 6X9s in the doors and 3.5s in the dash. Some observations:
1. The connector for the dash speakers is different from those for the door speakers. If you order the connector pigtails thinking they are all the same you will be disappointed. I removed the ones from the stock speakers and soldered them to the new speakers. Cutting and splicing is not an option given the tight quarters. The door speakers have the correct connectors.
2. Dodge engineers should be shot. There's no excuse for not making the door openings big enough to fit a standard aftermarket 6X9 with a 20 oz. magnet. Not only did the fronts hit the window rail, but the speaker opening on all the doors was too small. I had to heat the plastic on the rears to stretch them so the Kickers would sit flush in the hole and I had to cut some of the webbing out of the window rail mounting. The rail itself is not an issue, thankfully. On the fronts I had to use 1/2" spacers because I did not want to chop up the window rail.
3. The stock speakers are crap. Paper cones, no midrange or tweeters, small magnets and all made in Mexico.
4. New speakers really opened up the sound. I can actually hear something coming from the dash speakers now. The door speakers have some clarity and brightness and the rears now have some presence. So much so I was able to turn down the mids and highs from the 4 and 7 (respectively) that I had them at on the EQ to an acceptable 1 and 3. Much more natural sounding.
5. Removing/reinstalling the door panels on my 2012 is way, way easier than it was on my 2000 Ram.
Overall, I am very happy with the sound quality and with knowing that the speakers in the doors are much more durable than that paper crap they replaced. I don't need a subwoofer, so this was a pretty cheap and relatively easy mod.
cwakefld
Central IL
Great write up! Thank you
Stroked
Beloit, Kansas
Thanks for the write up! Do you think there's a round speaker like a 6 1/2" that would work better in the doors instead of the 6x9's?
Miami Son
Miami Son
Banned
Port St. Lucie, FL
Do you have any part numbers?
All the speakers are from the DS line of Kicker. Not quite as good as the KS line, but a lot cheaper. I paid about $150 shipped for all 6 speakers from Amazon. The wiring connectors to match the truck were another $6 a set and worth it. Just don't order 3 sets like I did since the dash connectors are different from the doors.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
I have the Kicker KS693 in my door, small fitment issue, nothing major, but huge upgrade. Glad you like them!
Miami Son
Miami Son
Banned
Port St. Lucie, FL
I just came back from a visit to the audio shop and discovered that Kicker are the oddballs. The Dodge speaker openings fit most aftermarket speakers, but Kicker makes their frames a slightly different size. Damn them!
Graygoose
Oklahoma
Convert, for now.
small
sorry :) Bigger basket.....
Bog8r
I just put the Polk Audio 6x9s and 6.5s in my 2008 and had minimal fitment issues. Definitely better than stock.
chipmaker
AZ
Go with the Bostons or Focals...
Graygoose
Oklahoma
Convert, for now.
small
I'll be keeping this in mind when I go to change my speakers as I plan on getting KS 693's. How do you get to the dash speakers by the way? I do plan on swapping those out also.
get in front corner, and use small pick to gently pry up factory grill.
quietpeen
2021 TRX
Hellcat
great info
jacsyl94
Corpus Christi, TX
my next set of modifications upon my return from a 90 day deployment...and a level.. Thanks for the information...
blackout11
alpharetts GA
2011 R/T
Just use a pick or small flat head to pry up the plate and have alot of patience because you dont have alot of room or wire to work with.
blackout11
alpharetts GA
2011 R/T
I got all the k/s ones for the doors and d/s for the dash (buddy works at fries electronics lol )
belive the dash are ds 35 and the 6x9 are ks 693
Graygoose
Oklahoma
Convert, for now.
small
yes, DS35 and I agree, KS69 or KS693 for door.
I know Fry's Electronics, there's alot fo them! Thats for sure.
