What PSI should I be running ?
stevens
2015 Dodge Ram sport 4x4 crew
Not sure exactly but what should I be putting in these tires for air . Im not sure of the max psi to be honest...There a Micky Thompson Baja atz p3 says max load 3750 lbs at 450 kpa ( 65 psi cold ) like so do I run all for at 50 psi ?? Thanks
Devin1349
I would say 65 if it says 65 cold but also look inside your drivers side door to see what the sticker says
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
Unloaded, you'll probably want to be down around 35-40 psi front and 30-35 psi rear. What size tire and on what size wheel? That partially determines the correct pressure to run.
stimpy433
IOWA
The sticker inside the drivers door is only good if he has the OEM factory tires still on his truck.
stevens
stevens
20"rim 37" tire x 12x50
Ferro
I would run them at 50.
CostaRam
Costa Rica
I run mine on 42 psi, same tire,
it seems to run well!
Chris
P.S. WRONG! I have the LT305/55/R20 Bahia ATZ, so your pressure may be different!
brandonjansen
Essentially the right way to check what pressure to run them at is to put chalk across the tread, drive a ways, and see how the chalk is wearing off. If it's only wearing in the center and not the outsides, the pressure is too high. If it's wearing off the outsides and not the center then the pressure is too low. Ideally you want even wear across the tread.
The numbers I stated above are likely where you want to be unloaded. I run 37x13.5 Toyo MT's on 22x12 wheels on my 3500 and run them at 40 psi front/35 psi rear unloaded. Your truck being that much lighter could even take a little pressure out of that.
Plus, the lower the pressure, the better the truck will ride over small bumps etc.
huntergreen
brandon is correct do the chalk test.
