whistle/shhhhh sound
Hessian577
Waldorf, Maryland
Hi all...I have a question, hopefully someone can help me out or lead me in the right direction. I have an 03 Ram with the 4.7 and 81,500 miles. I noticed a whistle/shhhh sound when I accelerate. I've looked at every line and hose I can and haven't found any bad ones. I cleaned the throttle body and replaced the gasket. I even replaced the resonator to throttle body connection tube. I can't pin point the sound but I believe its coming from the engine bay. No engine light appears and the engine performance is unchanged...responsive and strong. Any input would be greatly appreciated, thanks ;)
05daytona
Take the serpentine belt off and see if the noise goes away.
MegaMouseGW
South Louisianna
SRT 10 Viper Motor and Tranny
:signs16:
Ignore that. DO not remove your belt seeing as it runs the water pump alternator and several other needed things. Use a probe and see if you can tell just where the whistle is coming from. Belt squeal will be distinct and very loud and is quite different than what you are describing. May be a small hole in the airbox or somewhere else that you have not located yet.
moparman
Woonsocket, RI
2016 Ram 2500
Does it make the noise even if you rev it in park?
Sent from my Galaxy S3 using Tapatalk 2
Hessian577
Hessian577
Waldorf, Maryland
I checked the entire air box and resonator box...everything is solid. I thought maybe there was a loose connection to the throttle body so I replaced the connection tube. Yes, it still makes the sound if I rev it in park but not as distinct as when I'm accelerating while driving.
TexasRammer
College Station, TX
Does it get louder as you accelerate? Is your ac compressor on when it makes the noise, or does it happen while its off too? Could also be your alternator. You can do like what daytona said and take the belt off, start it up and give it some gas to see if the noise is still there
:signs16:
I think he just meant to take it off for a short time while its in park, not driving around with it off. He would still be fine as long as he doesnt run it too long and let it get up to temps/hot
MegaMouseGW
South Louisianna
Question: DP you have a throttle body spacer installed??? A lot of them will whistle when you accelerate. Look at your throttle body and see if there is a 1 inch spacer between it and the intake plenum. That may be what is making the noise maybe.:emotions36:
05daytona
:signs16:
I won't hurt a thing to run it for a min. to see if the noise goes away!
moparman
Woonsocket, RI
2016 Ram 2500
Agreed, no better way to diagnose it. Spin each accessory to see if anything feels funny. Almost sounds like alternator or water pump
Hessian577
Hessian577
Waldorf, Maryland
thanks fellas, I'm gonna try these suggestions and see what happens. Wish me luck because the noise is driving me offing bonkers. I can hear it over the Flowmasters. As for the TB spacer, I do no have one installedI replaced the gasket and its together solid.
JohnD72
Charleston, SC
When you're checking accessories with the belt off, spin each pulley quickly and listen for squeaks or other odd noises, but then turn them slowly, keeping your fingers on the pulley to feel for tight or sticky spots, shuddering, etc.
LS5DodgeRam
South Florida
4.7L v8
also check your power steering pump, my buddy's dad's gmc made a nice whistling noise which we all thought was the alternator... but while at the shop he found a leak in the power steering system, and the pump went bad.
I know it is a gmc... but it is a similar issue that we experienced
Ftank
