adrig
Two things:
1) I have had a whistling noise coming from the drivers side since I bought the truck. You don't hear it if the fan or radio is on but it it loud. Just brought it in and they said they resealed the windshield it did not fix the problem. Took it to Autoland in Springfield, New jersey and they did not check to see if the problem was fixed. Terrible service - does anyone know of a fix and what is causing it?
2) Autoland also replaced the gas tank because I was having a problem filling the tank. Today for example I wanted to check if the new tank corrected the problem. The gas pump kicked off at $4.50 and then I tried to see how full it was. Pumping in 20 to 50 cents at a time I got to $20 and it still was not full. This is the new style tank without a cap. My other rebel did not have the same problem.
