will a bull bar void a warranty?
Cecil_
I live in west virginia
2011 SLT
like the tittle says "will a bull bar void the warranty?" im considering adding one and am worried about this.
Burla
2010 Hemi Reg Cab 4x4
No way, unless it blocks the radiator from flow, which most BB don't.
huntergreen
I don't see how a normal bull bar could void anything.
MADDOG
Out Exploring Arizona
The only warranty I see as possibly being affected is if you have to drill a hole that eventually will rust out.
Riccochet
Somewhere around Charlotte
2020 2500 Laramie Longhorn
Knowing stealerships, they be like "what's that? You changed your floor mats? Sorry, but that voids your engine warranty"
H1Chester
No.
Magnuson–Moss Warranty Act.
Cecil_
Cecil_
2011 SLT
installing a bull bar can i use a impact gun?
hi all i was wondering if it would be a good idea to use a impact gun in the hexbolts that hold on the factory tow hooks? the plates that the bull bar mounts up to uses the same bolts that the tow hooks use, I tried muscleing them of, no go.
jdavila99999
Could heat them
WilliamS
Tampa FL
As long as its the right bit and its an impact specific bit. I use my torx bits on my impact all the time for things like seat belt bolts and bed bolts. Make sure you have the right sized bit, not close enough and make sure its rated for the impact.
scott5626
Indiana
I’m considering a Bull bar myself. I’m also concerned about warranty issues because of the Bull bar possibly effecting the air bag deployment. Also I’d want some led lights and custom wiring is also a reason for the dealer to blame you for any electrical issues that could arise.
