Try the AFE shorties or go full mod manic for the longtubes. I think @danielmid has that brand shorties.What kind of mods should i put? I have a manifold leak thats why i was going to for the bbks
Diablo Hater!If you're worried about warranty, leave it stock until you aren't.
Tune (not diablo), long tubes, 6.4L intake manifold (as long as you aren't etorque), cam. Don't waste money on throttle body or cold air intake.
the stock air intake is a cold air intake. Have your manifold bolts fixed under warranty. See if the dealer will have them machined at your expense, won’t warp again according to some Ram techs on the forum. Since dealers and Chrysler do their best not honor warranty repairs, I let you decide if a tuner will void your warranty.I have a 2109 ram laraime which i just paid for an extended warranty. If i put some bbk headers, a K&N cold intake and a diablo tuner on there will it void my warranty?
None if you still want your warrenty to be any good.As stated have your original manifolds machined or sanded flat and re-install them with new bolts and gaskets.I reconmend using Remflex 6022 gaskets,they are a thicker graphite gasket that will absorb warpage better then the factory MLS gaskets willWhat kind of mods should i put? I have a manifold leak thats why i was going to for the bbks
If you want Headers and a Cold Air Intake, take the truck to a Ram Service Center, buy the parts thru the dealership and have them install them. That way they are covered under the warrentyI have a 2109 ram laraime which i just paid for an extended warranty. If i put some bbk headers, a K&N cold intake and a diablo tuner on there will it void my warranty?
The mods you are considering will void the warantee. The headers will require you to adjust the tune on the vehicle wich will automatically void the warantee. Not to mention if you plan on deleting the cats, which is illegal, which will void the warantee on the motor and exhaust system............A cold air intake is....well....stupid to begine with, but if you bypass any of the emission systems to use it, like the pvc system or, again, retuning the computer because you just threw the air temp and flow out of whack, by by warantee on the engine, not to mention it is illegal in most states to bypass anything emission..............About the stupid...........The ONLY place a cold air intake is going to increase performace is strapped to a dyno with a shop fan blowing air over the engine.......The factory air system is designed to pull air from the fender wells or outside of the engine bay....where the hotest air possible can be found. A cold air intake, when you take it off the dyno, unplug the shop fan, close the hood, is going to pull air from, yep, the engine bay. It will become a hot air intake instead of a cold air intake.........and hurt performance on hot days...........That is not even considering how much time and money dodge spent to make sure the air intake system is capable of supplying MORE air than the engine could possible demand at peak performace. you would have to stuff a cam in it and put bigger pistons in the motor or a super/turbo charger to make that motor need more air than the system on the truck was designed to deliver............it is the shiny for the kids who dont know any better. Will not help. Can hurt..........Same with headers. have you considered how much effort dodge put in to make sure the factory exhaust system was shielded from vital areas of the truck? Do you think heat shields are decoration? Do you think removing it and parking super hot heders next to the starter motor and other plastic sensors is the bomb?.............if you want to drive it every day, leave it alone. If you like working on trucks instead of going on dates, have at it.I have a 2109 ram laraime which i just paid for an extended warranty. If i put some bbk headers, a K&N cold intake and a diablo tuner on there will it void my warranty?
I' did the machining on my manifold a few years ago, no problem since. The older, the higher mileage that the manifolds are, the better. After they have been thermally cycled enough, all the stresses are relieved. The primary cause of broken bolts and leaking gaskets is the distortion that happened over time on new manifolds. Once they are stress relieved, it is the end of the problem.the stock air intake is a cold air intake. Have your manifold bolts fixed under warranty. See if the dealer will have them machined at your expense, won’t warp again according to some Ram techs on the forum. Since dealers and Chrysler do their best not honor warranty repairs, I let you decide if a tuner will void your warranty.
They are particularly bad since stellantis took over, they are apparently dictating to dealers with an iron fist.It largely depends on your dealer. But, almost all dealers are now very stringent and intolerant of modifications that alter the performance or stock design of engine and transmission parts. This may even apply to things like suspension modifications. Be very aware and very careful of doing anything that a dealer can claim is a failure due to the owners alterations. And good luck hiring a lawyer and fighting a claim using the Magnuson-Moss Warranty Act.
