!!!WTF just came out the radiator!!!!
generalat2
phoenix az
5.9 magnum
Not sure what came out the radiator????
generalat2
generalat2
phoenix az
5.9 magnum
Here's another pic
RamV10
Western Central NV
V10
I agree, Looks like a new radiator is in order. What does the trans fluid look like?
Administrator
Was the antifreeze orange to begin with? You may want to check the transmission fluid and the motor oil.
auskip07
s
s
coolant with motor oil forms a "milkshake" that looks like a milk shake color
generalat2
generalat2
phoenix az
5.9 magnum
Checked trans fluid, was low, started to fill up and engine overheated spewing out the pepto bismol milkshake. Didn't notice anything in trans fluid other than it being low. Truck has a few small leaks. Engine oil is clean. Radiator was replaced last year, brand new from autozone. Radiator only had water in it when this happened. It's a 01 Ram 5.9 4x4
shortlid
Derry, NH
Magnum 5.2
was it distilled water or tap? Not even water wetter in there to prevent corrosion?
generalat2
generalat2
phoenix az
5.9 magnum
generalat2
generalat2
phoenix az
5.9 magnum
Distilled. I'm thinking where the trans lines go in the the barrel cracked and fluid leaked in.
dapepper9
Iowa/Nebraska Border
5.9L V8
You need to replace the radiator, flush your entire engine cooling system that now has ATF inside it, and drain and flush your trans to get the water/antifreeze out.
Gr8bawana
6.7 CTD
Perhaps a leak in the trans cooling line that runs through the radiator?
You would be surprised how many people run staight water in vehicles.
auskip07
s
s
by the way my wife had a autozone brand (what ever brand they sell) radiator that wasnt very good lasted maybe 2 years. So i researched and found that most mechanics trust certain brands of radiators. CSF radiator brand makes a good radiator.
Harleygtp
Cummins 12v
Okay, so the engine oil is good? Do an oil change and make sure you don't have any of that milkshake stuff in the pan. Checking the dipstick is NOT good enough.
It is more than likely a bad trans cooler line inside your radiator. Now, everyone who is screaming about killing your trans...take it easy. The trans fluid is at a MUCH higher pressure than the coolant, so if there is a problem, it is doubtful that coolant got into the trans. To be safe, drop the pan on the trans and inspect.
Replace radiator, do a coolant flush and trans flush. You'll be good to go.
joepizuro
Magnum v10
I ran a cavvy with straight water in the rad for a year until I changed it for winter by dumping straight antifreeze in it lol
Harleygtp
Cummins 12v
No harm in running straight distilled water in a cooling system. Coolant simply allows for more efficient heat transfer.
Gr8bawana
6.7 CTD
Running straight water gives you ZERO protection against rust.
Orca
