12 Ram Express
I tried the install on the dodge dart and it went fine until i noticed that after the car has been remotely started you can no longer use the key fob to lock or unlock doors you have to use the metal key to manually get in and put the key in and if u take it out the motor wont shut off until you press the break i didnt try to drive it around then take the key out to see if that stops the motor but when i look on the xpresskits website in the flashing process when you choose 3x start without the smart key it says that is a normal feature of the firmware that u can only get in with a manual key after its started....did any of you guys experience this with your standard key on the the ram not the push button start kind
