2/4 drop? Post your info here!
Twizzy228
Illinois
If you have dropped your 4th gen 2/4, post the specs of your truck and whether or not you have a wobble.
I'm installing a Belltech 964sp on mine and will post my info once I'm done.
Here's a template so we can have something easy to glance at instead of sifting through posts to get the pertinent information.
Cab configuration:
2wd or 4wd:
Brand of drop kit:
Wobble: yes or no
Speed you experience wobble:
How you fixed it:
Lhemi
OKC OK
6.7 Cummins Turbo & Hemi 5.7
2012 Ram R/T Reg cab
Belltech2/4 w/street performance shock.
60 the night I dropped it.
Spohn Adjusble Pan Hard Bar
Still there just not as bad
BlkRamRt
SoCal
HEMI 5.7
Cab configuration: 2012 Ram R/T regular cab
2wd or 4wd: 2wd
Brand of drop kit: Belltech 964sp
Wobble: yes
Speed you experience wobble: 70-80mph
How you fixed it: Spohn panhard bar but it still has a slight wobble
TylerB
FL
RCSB Express
2WD
Belltech 964SP(soon to be switching the front Belltech coils to McGaughy's 2" coils and 2" spindles)
No wobble
No track bar relocation bracket, only the Spohn adjustable track bar. Still using stock upper and lower link bars.
chrisb38002
Lakeland, TN
That is 2 out of 2 wobble for the belltech on R/T's. Curious to see if anyone with the McGaughy kits have the same issues, because I just ordered mine this weekend.
Jizanthapus
Orange County, CA
It's not just the belltechs that are going to produce the wobble. The problem stems from altering the height at all of your rear-end. It throws the geometry of the 4-link out and your axle shifts over.
The "relocation bracket" from McGaughys and Belltech is a band aid and doesn't even cure the problem.
Lhemi
OKC OK
I forgot to add the relocation bracket.
jay c
Las Vegas, Nv
configuration: 2012 Express quad cab
2wd or 4wd: 2wd
Brand of drop kit: BT 964SP
Wobble: no
Speed you experience wobble: n/a
* used the relocation bracket tires are centered panhard bar is pretty parallel to the ground.
Team Destrucktive
delunad
Texas
2013 express quad cab 2wd
Belltech with nitro shocks relocation bracket and sway bar links
No wobble
T
Twizzy228
Illinois
Cab configuration: reg cab R/T
2wd or 4wd: 2wd
Wobble: slight
Speed you experience wobble: 65+
How you fixed it: haven't yet, might not be enough to do anything
Mr.Smith
East TN
So does anyone with a non R/T and the bracket have the wobble. What is the difference In R/T rear
Exhausted
Edmond, OK
this was on my old truck
Cab configuration: Crew
2wd or 4wd: 2wd
Brand of drop kit: McGaughys Econo Drop kit
Wobble: No
Speed you experience wobble: N/A
How you fixed it: N/A
SILVER_BULLET
this is for my first drop ill update it soon with the belltech kit i got last week
Cab configuration: reg cab rt
2wd or 4wd: 2wd
Brand of drop kit: pieced together so dont really remember but it was a 2/4 and since it was different parts i also didnt have a relocation bracket and havent bought an adjustable bar yet
Wobble: yes or no: no
Speed you experience wobble:none
How you fixed it:
chrisb38002
Lakeland, TN
Cab configuration: 2013 RCSB R/T
2wd or 4wd: 2wd
Brand of drop kit: McGaughy's 2/4 Deluxe
Wobble: No (at least not up to 90 mph which is as fast as I've had it after the install)
I also have the Spohn adjustable track bar installed.
sbwrench
2012 Express
Panhard relocation bracket that cam with the kit
No wobble
2711
HEMI 5.7
The only member on this forum that I know for sure has lowered his truck properly with perfect alignment is UNBROKEN... no wobble there.
MaineRam
York, ME
Ive been searching and can't seem to pin it down, but has anyone lowered a 4x4 with these kits? I am only looking for a 2/4 drop. Not sure if you can use the McGhauy's kit with the knuckle and springs? I doubt the springs all around kits will work.
I have a 2012 Ram 1500 quad 4x4
MR.REMBERT
Santa Barbara County, CA
2013 RCSB Express
2WD
Chopped Belltech 2/4 w/ "street performance" shocks
No wobble at 105 (no tuner, can't go faster than that)
Also added spohn adjustable panhard, helwig front and rear antisway
DavidRam
SoCal - Redondo Beach
2012 RCSB
Cab configuration: RCSB
2wd or 4wd: 2wd
Brand of drop kit: Belltech 964sp, Street Performance shocks, Hellwig swaybars front and back, Spohn adj. panhard bar, Spohn adj upper and lower control arms
Wobble: None
