Aux backup lights installed today
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Finally had a moment to put some backup lights on the truck. Kept saying.....when its not blistering hot, and I have some time. The moons aligned today - 75 degrees out, I took advantage! :roflsquared:
Anyway, these are the same LED pods that I have hooked up as DRLs on the truck. We stock them on the site here, if anyone is interested in a very cheap and easy hookup for backup lights (or any aux lighting for that matter) - Morimoto x.DRLs / Backup lights
Mounted them to the bottom of the bumper. Thought about between the tailgate and bumper......but - just didn't like the idea. There was also a spot behind the back wheels I thought about, but too much light would be lost from that. I wanted the MOST light output - and this will do that!
Connections were very simple. I pulled the 7 pin connector off, tapped the middle wire (WT/RD) for the positive (thats the reverse wire on the 7 pin) and then grounded on the BK/GY wire. Got the wires out of the way, all done. Took about......25 minutes start to finish. :favorites13:
Pics!
argray90
NW Burbs, IL
The WT/RD on the 7 pin connector is the reverse light? So much easier then pulling the tail lights. Need to wire mine up for reverse now.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
yeah, the one right in the middle. White / Red.
I was getting ready to wire it up, dropped the tailgate, grabbed the tools ........ and went....... "drrrr, 7pin has it!" - saved some time there.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I have a handful in stock, putting in my stock order now for 10 more! ;)
TRCM
USN, Retired
Newport News, VA
2012 1500 Laramie CC 4x4
Same thing I did to my Cherokee, but I used some white driving lights I had bought many years ago for this same thing on my dually. Anyway, they work great, especially when coming out of the woods at night after a day of hunting. Really makes it easy to see what's behind you.
I hard wired mine in with a relay though at the passenger side tail-light.
Vancouver604
Hemi 5.7L V8
is it possible to use these on the hood of my sport hood? / \
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I'm not sure they'd fit. Here are the overall dimensions:
Height: 28mm
Length: 160mm
Depth (front of LED to back of bracket): 37mm
Depth (front of LED to back of heat sink): 26mm
Depth (Just the heat sink): 14mm
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
yup. still..........not dark. lol
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
yeah, she's close! tight fit. ;)
LB3711
Trumbull, CT
3.6L V6
sweet. between the cree reverse lights and now those its gotta be daylight back there
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
we'll see soon! its starting to darken up around here. ;)
TRXHemi
Sugar Land, TX
I love mine. I ended up running a wire and have a switch to kick them on whenever necessary. I used to pull a trailer so it was handy at night.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Pic time!!
Went up to the warehouse, the first couple shots are about 40 ft away from the wall. Grabbed the wrong lens.....using my 35MM prime lens - so, a lot of stuff looks "closer" than it really is. Second grouping of them is where the trucks go to turn around and stuff, and there's a LOT of room back there.
through the closed window, 20% tint.
back window, open. So, the dark spots are 2 "windows" deep
LOFSFIRE
2013 1500 CC Sport Copperhead Pearl & 2011 1500 CC Sport Black
5.7 Hemi w/ 8 speed ~ 5.7 Hemi w/ 6 speed
Looks good! Now think about this, instead of running them off the trailer reverse light wire, run them off a powered relay and set it up to be activated by the trailer wire or a switch mounted in your bed (or spot of your choice). If you go camping or ever need to work around you truck a night just flip the switch and you have work lights too. Those LED can burn a long time without the truck on.
