Bilstein Adjustable 5100 and 35's
ctechnow
I've done some searching but I haven't been able to find a cut and dry answer about this. My Shocks/Struts are shot at about 85k and I want to replace them with the Bilstein 5100 adjustable's set at max height. The only problem that I've heard is that they will rub if I get the tires that I want which are 35/12.5/20. I've read about wheel spacer's, can someone with this setup post a reply and send me a link to the wheel space that I would need to eliminate any rubbing? Any downside to the wheel spacer's? I'm considering a full lift down the road but I'd like to start with the 35's and level first. Thanks for any help in advance!
quietpeen
2021 TRX
Hellcat
i moved this to the lifted section.
you could get away with 1/4" wheel spacers
Arturo Rojas
