typo_joe
The audio bug has bitten and I'm torn in which direction to take with adding a sub/amp combo to my truck. Warning: this may get geeky!
I have:
1 - 12" Eclipse Aluminum Cone - Single 6 ohm Voice Coil (yeah I know)
2 - 10" Kicker Comp VR - Dual 2 ohm Voice Coils
I Want:
Ultimately, I want tight, hard hitting bass that is clean and crisp with decent low frequency handling. I'm not looking to set off car alarms. Just a powerful punch to add the first step in my SQ goal. Ideally, I would like to have a single sub with the amp mounted beneath the drivers seat. Leaving the center and passenger side storage available. I don't want to remove the cargo tray either. The lower I can keep the height of the box the better. The more 'stealth', 'sleek' and 'clean' the better.
I Need:
• An amp
• Build a box.
I realize there's plenty of other stuff (LOC, wires, etc), but those are minor in comparison.
Now, I have built a lot of boxes. Several before I knew what I was doing (poor construction techniques and no concern of air volume) and a whole lot more after. Seemed like I turned into the box builder in my old car audio group of friends. If I wasn't doing it myself, I was helping them, but I loved it either way. Please don't misunderstand, I'm not saying I'm great or trying to brag in anyway, but I can satisfy my picky a*s, so I'm happy.
My thoughts are to construct a typical sealed, wedge truck box with an 'extension' that fits into the cargo tray. If you look at the outside, it would look like there's a truck wedge box sitting on top of the cargo tray. I would like to figure out how to secure the box using the mounting point of the tray that the box will cover. It shouldn't be too difficult. There are some hooks of some sort on the back wall, I'm going to keep the box below these and no wider than the seat, if I can. The constraints will limit the air volume available, but the 12 has a sealed box volume of 0.5-1.0 cu ft. The 10s, I'm not sure about (they too are pretty old), but I can assure you it needs to be larger than the 12. Eventually, the box will be finished with carpet to match the interior and if forward or rear(?) firing, it will have a grill, of some sort.
The Amp:
See My Choices
My Choices:
As I mentioned, way up there, I have three subs. A pair of, dare I say decent, 10s and an old, yet beast of a 12. I can give some details if anyones interested... its a sad story really. lol.
My first thought:
• Buy an amp for the 6 ohm 12 and build a box for it.
Then after considering the price of the amp I will need for the odd 6 ohm sub in a small box (=more power) and the construction limitations caused by this monster sub I'm thinking I might:
• Buy an amp for one of the 10s and build a box for it. This box would probably need to be larger than the 12 due to the volume requirements. Which would hurt the Wants listed above. Also, this sub may not deliver the punch I'm looking for by itself.
As an outside, tiny chance, a third option:
• Buy a new 2 ohm dvc 12 (maybe a 10), an amp and build a box for the new sub. This would be nice, but maybe not economically smart or even viable. I know it would be difficult for me to find a sub/amp combo that I could afford and could be happy with that was better then what I could do now. Truth be told, I could just build a box and go. I do have a couple or three amps laying around the house some where, but they aren't worthy... well one maybe if I go with the single 10 I already have. That's worst case though cause that amp was old when I bought it and has been punished over the years.
Okay. Clearly I can get wordy (mentioned in another thread). Thanks for sticking with me, if you skipped ahead,
, but I don't blame you.
So what do you think. What would you do? Remember small budget. Any questions, to help advise, let me know.
Thanks in advance.
I have:
I Want:
I Need:
• An amp
• Build a box.
The Amp:
See My Choices
My Choices:
My first thought:
, but I don't blame you.So what do you think. What would you do? Remember small budget. Any questions, to help advise, let me know.
Thanks in advance.
