quad light hid install help please
joeg45
Katy, Tx
ok i just bought new hids i got my fogs in no problem but how are you wiring the headlights in the factory quad headlights are you drilling out a whole in the low beam cover to put the wires through anybody i need help please pics would be great as well
Vendor
Florissant, MO
2x 5.7L & 6.2L
joeg45
joeg45
Katy, Tx
so got up this morning and i went outside was freezing but started on my truck finally got all four of my HIDs in heres some pics i took
after i took out the grill and headlights
took off the cover and drilled out a whole with my dremel and feed the wires through
tested my lights all good :D
put it all back together
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
spiffy
joeg45
joeg45
Katy, Tx
Why thank you also after I did this my dads friend finally showed up to tint my Windows :D lol 20% up front 5% back
joeg45
joeg45
Katy, Tx
Thanks guys a little more than just plug and play compared to the dual head lights or my previous charger I had I liked that I didn't need the relay harness with capacitior or the canceler thing worked perfectly with just the ballast and hid
a_guerrajr
Houston
HEMI 5.7
Ok, so enlighten me. I'm use to needing a relay and all that.
So i don't need that on Dodge?
ALso I need to drill the housing on the lights, doesn't that allow for moisture to build up?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Some trucks seem to work without the harness, but I don't trust it. Why chance it?
On the housings, if you drill into the dust cap and use the grommet that comes with the HID bulbs, you will be fine. I use a 1" hole saw, but a 7/8" will work great too.
joeg45
joeg45
Katy, Tx
So was I or.using a canceler on the wiring but I tried it with out anything still have it.like that no flickering no warm wires nothing heating up unusually so for now I'm gonna leave it like this for a little bit until I get a new harness for it.
But you can always add some silicone between the gromet and housing to seal it better
Bobbyk71081
Boston, MA
2011 bighorn
Hey guys i got a 11 bighorn 1500, tonight i just installed hids in the fogs and headlights..everything came out fine, no flickering but when i turn my fogs on its tripping the tire pressure light..has this happened to anyone else? Could it be because i had the front end jacked up off the ground?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
thats normal. the frequency is crossed into the TPMS frequencies - it pops that light for a second. all good
bashby80
Mountain Home, ID (not by choice)
Just wanna say I installed my HID kit just now Thanks to this post. I had to pop the coupler off the extension wires to mate it to the stock one, but they all work!
bashby80
Well...my lights work just fine, when the truck is off...running, I get the flickers (fogs are fine). How do I do the resistor/capacitor thing? I can't seem to find a thread on that specifically.
SILVER_BULLET
I have not looked at my lights or anything so can someone enlighten me as to why you need to drill something?
bashby80
Mainly due to the kit being a two wire system and the factory clip going into the headlight housing is a three, but the other clips inside the housing (one for each bulb) are two wire clips.
Steve58
