Raptor Style Amber LED Grille lights
muddy12
Indiana
JB1
JB1
Houston, Texas
Looks great
Do the Red lights run whenever lights are on or just with brake lights?
muddy12
Indiana
Looks great
Those are on with the tail lights.
I’ve got another 6 of the red ones to install (going to put 3 on each side) that will be tied into the brake/signal lights. Just waiting on the weather to warm up a bit.
Outdoors76
CT
wired mine similar to jb1 with the conduit and connectors and shrinktube wired to pass fog also.
i used a pc of sheet netal bent 90 degrees screwed to top painted black to mount the lights.
thanks for the post jb1.
jdavila99999
Looking sharp !
Marsch
Nashville TN
I like the concept of these. I think I will add it to the list of things to do. Thanks for the write up!
Reactions: JB1
JB1
JB1
Houston, Texas
Thanks, I have them wired up to my AEV switches now so I can turn them on whenever
MrRickbo
Harlingen, Tx
3.6 Pentastar
looks really good, if i didnt already have the rapter style grill with the 3 LEDs in it, id probably copy this idea
Got the same grill! I love it! Great price on it as well. The only thing I didn't like was that I could reuse the grill shutter air dam from the factory one.
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
@JB1 what size did you buy? I got the 6mm, but I have a feeling looking at yours they are the 16mm. Now what do I do with these tiny 6mm versions? they're amber
JB1
JB1
Houston, Texas
I bought the 11mm which is the thread size (use 1/2” drill) and the bezel is 15mm, with 16mm the bezel is 20mm which is too big for the opening in the honeycomb grill (3/4” or 18mm)
Believe it or not there was a lot of thought, design and planning on how I did this and the parts selected.
Sorry, wish you would have asked me first. :shrug:
TXCOMT
Good writeup, but I found some white LED fixtures at Academy (of all places) meant for marine use...I'll install those as I don't like amber running lights (especially if they mimic a Ford).
TXCOMT
shadowhawk
Southeast WI
TXCOMT
I believe people run amber because LEO can get picky on running too many white lights.
JB1
JB1
Houston, Texas
TXCOMT
The ones I used come in many colors, even dual so you can wire them as strobes
I look forward to seeing what you come up with and how they mount
TXCOMT
Me, too!
Here's what I got...again, 'cause they were on sale! Initially, I thought I'd do 'em as reverse lights, but they're probably not bright enough to blind folks (and isn't that the point of aftermarket reverse lighting in general?). I imagine the look will be similar to what others with strip lights have posted here (Muddy, BEAST). I've got five, so I'll either do three (with the others as spares) or hook 'em all up just to be different.
https://www.academy.com/shop/browse...ials/boat-lights/utility-lights?beginIndex=30
TXCOMT
Reactions: JB1
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Morganntk
