I just bought a very clean, gently used (turns out it was a 'toad' behind a motor home) 2019 Ram 2500. Excellent condition, and only 59,000 miles. It's got the Bighorn package (which I had on my recently traded-in 2019 Ram 1500 Classic) but not quite all the same bells and whistles - including NO fog lamps. The dealership told me the plastic 'blanks' in the bumper can be knocked out and that the harnesses for fog lamps are there in the bumper. The light switch has the push-button for fog lamps incorporated within it, and if you push it, it lights up a fog lamp icon on the dash - just like my other one did. (Only it's orange instead of green; perhaps because working fog lamps aren't present?)
Anyway, I want to add some fog lamps. I can't find specifics on older posts, so any information would be helpful. Can I safely assume the harness leads for fog lamps are present, and if so, work with the same 'push' button feature in the center of the light switch? Are there aftermarket fog lamps that will plug and play into said harness, or do you have to adapt them three ways from Thursday?
Thanks!
Thanks!
