Factory ordering a 2023 Ram 3500
Sam Monteleone
Kansas City Mo
V8
I never planned on towing, but I got bitten by the travel trailer bug. I have a 2020 Ram 1500 Limited Blackout towing my new travel trailer. The payload is almost maxed out so I am thinking about ordering a new Ram 3500. Can anyone give me some tips on doing a factory order? Also, what type of discount should I expect on a special order. When I purchased my 2020 I got just under 18% off MSRP. Times have changed, and I don't think I could get that much of a discount now. Thanks for any help!
jejb
NW Arkansas
You are not far from Des Moines, so call Granger Motors up there. If you order a truck, they are at 4% under invoice, so about 11.5% off of MSRP. Worked great for me last year, no hassles at all. That is probably the best deal you are going to find these days.
Scott0700
Rexford, NY
Also test drive the 2500 and the 3500. If you don’t need the bed payload of the 3500, get the 2500. They both tow the same amount. The 2500 rides so much better. Coils (2500) in rear vs leaf springs (3500). When I test drove the SRW 3500, I asked the salesman “Does it have a rear suspension, or do they just weld the axle to the frame?” It rode that bad compared to my 2500.
06 Dodge
Forest Grove, Oregon
6.7L CTD
The 3500 has leaf springs that is why it has a harsher ride then the 2500 with Coils, sometimes I think they put coils in the 2500 to make it ride more like a Car/SUV, but then is also has a smaller payload then the 3500 with leaf springs and IIRC the 3500 can have 4.10 gears that increase tow capacity...
jejb
NW Arkansas
That's very true. I test drove a couple of 3500's last year before ordering out my 2500. I already owned an 18 2500 with factory air suspension, and do not need the extra specs the 3500 has. But thought about future proofing and stepping up the 1 ton anyway. Test drives killed that idea. Totally get it if you need the capacities of the 3500, and most do that haul RV's of any size. But there is a big difference in unloaded driving.
S
Sam Monteleone
Kansas City Mo
V8
Thanks for the info. They are a 3hr drive for me. Right now I am not sure what I want. I can get the Ford A plan that gets me a decked out F350 Lariat for 71k. I test drove a 3500 and it was very rough. When I got back into my 1500 it felt like a Lexus. One thing that is putting me off from the Ram 3500 is the massive humps on the floor on the passenger side and back. The 1500 doesn't have that. The Ford F350 doesn't have it either. I will give them a call and see what price they give me on a 3500 Laramie. Best my local Ram dealership would do is 79700 off 85000MSRP. One plus for the Ram is the height fits into my garage. The Ford is off by about 1inch requiring it to sit outside.
Mark Dodge is a dealership in Louisiana
The are also a Vendor on this forum
They have some kind of special discounted promotion on Factory Orders right now
jejb
NW Arkansas
Never noticed any humps in the floor of my 22 Ram 2500, but we all notice different stuff. BTW, Granger is also a Ford dealer, and I believe they give the same discount on ordering a Ford.
1 tons and better are going to ride pretty rough unloaded. Not much getting around that one. Would not be much fun as a daily driver, I'd guess.
Not many people cruise around in 3/4 ton & heavier trucks
I can picture it now, a landscape crew, cruisin' the mall on Saturday night
S
Sam Monteleone
Kansas City Mo
V8
The humps are because the cabs are the old style not like the 5th gen 1500s. The passenger side and rear of the 1500's are flat. In the 2500 and 3500 they have big humps because they use the 4th gen chassis. I saw they were Ford dealers too. My nephew works at Ford building vans so I can use his A plan. I assume that plan is the same at any dealer, but I will get a quote just to be sure. My local Ford quoted me 71k for a Lariat 350 SRW with nearly all the options and Godzilla engine. Maybe they can do better. I sent my Ram build off to them, now I am waiting to hear back.
jejb
NW Arkansas
I thought the rear floor was flat in my 22. I'll have to fold the seats up and look. I leave them folded down pretty much all the time. And I have the front buckets with full console, so the tranny hump is pretty well hidden.
jejb
NW Arkansas
I sure don't. But a lot of folks do, from reading the truck forums. Not everyone can afford that extra vehicle so they can leave their puller parked between uses.
06 Dodge
6.7L CTD
In my 2022 2500 BH the only hump in the back floor is the one for the drive line the rest is flat...
jejb
NW Arkansas
I looked at mine yesterday. There is no hump in the back seat area. Where the front center console ends, the hump ends. It is a 22 2500 Limited Longhorn Megacab 4x4.
metro ATL
I drive a '22 one-ton SRW daily in the metropolis/city. I get 9-12 mpg depending, if Im flooring it or not. I get 14-18 mpg driving on the HWY, but I drive 75+ mostly. It can be bouncy (is the word I'd use) on terrible roads. I drove a supercar daily, so it's no different to me as far as harshness. Like my - former - STi I jump or blaze over all normal obstacles & hazards, but I get to also go over curbs in the 3500.
I dislike 1500s now and wouldn't ever own a non-HD truck again. When I was optioning a 2500, I was adding tow-hooks, locking differential, and couple of other options to make it more HD - which made it $200 less than a 3500. Therefore, I got all that and significantly more payload with the 3500 for a little more. Firstly, I was advised (here), because of payload, to get the 3500; however, I did have to research for myself, and they were 110% right.
I put two 4K loads of large rocks on a crate in the bed of my truck. I don't think it squatted at all, but if it did it was less than .25 of an inch. I got 9 mpg driving carefully home - all stop and go city. Its ride was smooth as butter under payload.
I have a Z06 and just got a new KLR650. Incredible gas mileage on both of them, but I always want to drive the "Big Easy" truck. I drive a one-ton daily and have other great options. I don't care about an extra few miles per gallon of a 1500 or the 1-2 a 3/4 ton would give.
At first, I didn't understand what all the harshness was about on the 3500. It took a pretty terrible section of road to understand what others were saying. YMMV.
jimmyfjk
hemi
not sure about 2500 or 1500 models but Ram has ended being able to order a new 2023 3500. You will have to find one on a lot if you can.
